went out and bought the 760 Holley Truck Advenger and wired it up to see if it was going to run.
it turned over but it started like it was a very tight engine.
I thought it might be because it was newly rebuit but I was wrong. found engine problem #1 the push rods were bent? WTF
so I pulled both heads and replaced them.
put everything back together and started her up. sounded good but running at around 3000 RPM's.
we I figured I would install a new exaust and then try and tune the carb.
fabed up a new glasspack exaust and started her up. from ouside of the cab
well this is why I named her Christine. when I started her up she was still in gear. Instead of her starting up and then dying it started moving down the driveway. I tried to jump in to stop her but Failed and got my leg cought in the spot between the cluch and the door. She drug me down the drivway and though a fence
and into a tree. with me under her the whole time. So to make a long story longer SHE TRIED TO KILL ME
so I named her Christine. Sorry got on a tangent there.
After that found engine problem #2. She quieted down a little after the exaust was ran but now I here a knock WTF
So we pulled the oil pan and sure enough the rod bearing need to e replaced. so the newly rebuilt engine a friendput together for me now is just a paper weight.
