Chinese knock off carb question
BALLSTON LAkE, NY
Good evening, looking for some advice on a Chinese knock off carburetor (Amazon special).
Here are the details:
- 74 F.5 engine came with a Weber carb
- removed Weber and installed Chinese knock off
- carb has been used for 6+ months with no issues, been on the road for the last month and about 400 road miles on it.
- changed out the fuel pump last week, first trip after was great, truck ran well.
- On the way home , I was on the exit ramp and let off of the gas and it seemed off. Pulled in to get gas and it wouldn’t idle. Got home and checked timing, idle adjustments, typical vacuum leaks, idle solenoid. Just couldn’t get it to idle, parked it for the night.
- fired right up the next day and idled like nothing was wrong.
- fired it up today and it was back to the iradict idle again. One minute it’s fine and the next it wouldn't run. Check for vacuum leaks, checked the idle solenoid. Nothing seemed to make sense why one min it was fine and the next a drop in vacuum and rough to almost no idle at all.
- pulled the horn, revved up to 2k and then put a gloved hand over the carb several times. Didnt seem to shake any thing loose, still idled fine for several minutes and then it wouldnt. Fuel in the sight glass was consistent so i dont believe the pump is the issue. I checked and the nozzle seemed to spray fine too.
- pulled the carb, checked the intake (no visible cracks), checked all hose connections, re-torqued the manifold nuts (a couple got a 1/4 turn before clicking). Disassembled the carb, pulled the jets, sprayed in the oraffices, and the jets too. I did have one small spec boil out of the main jet.
- wondering if there is something else I need to check before I reassemble. The carb seems a good copy of the OE and I used the schematic to disassemble-reassemble.
Thanks for any and all assistance and advice.
Thanks Matt, kinda had a hunch but wasnt sure how to diagnose. When I cut the power it cuts out like it should. Reconnect and seems fine. Do they work intermittently?
Would a stock solenoid work as a replacement, or do i need to pull it and clean a contact or something?
so I went back through the carb, removed the solenoid, blew out all ports i could find and then reassembled. I did find some fine filings once everything was back together, not sure what port they came out of. Reinstalled and started the truck, seems to be back to normal. So my guess is I either knocked something loose in the carb after several months of the new fuel pump had some fine filings that clogged up the idle circuit. Raining so it will be several days before i can road test.
i would install a NEW FJ60 THICK media type fuel filter on your system before you drive it or start the engine again ..........
HERE is what you need :
DO not install any other filter this BLOCKS ALL foreign matter 99.9% SOLID results ...
thanks, will need to check it out. Still wondering if the new fuel pump contributed to the metal pieces i found after flushing out the carb, or maybe it was in there all along and finally dislodged.
thanks again!
I am using a fuel cut solenoid from an aisan in my amazon special. I traced an earlier inconsistant idle to that part. Never a problem since, and it runs and idles extremely well.
Good to know, after I cleaned it i only started it up to get it to temp. I will look in to it, I’m sure Matt was spot on with his recommendation. Drove me nuts as everything is new or rebuilt. And the hit end miss when it acted up made me question the solenoid.
Any one in particular on Amazon to buy from?
So the two wire solenoid from your Aisan fit just fine in the chinese carburetor? I was worried how I was going to connect the wires. I read somewhere that only one wire needs to be connected to the solenoid and the other ground to the car.
Yes, both work. The 1 wire solenoid is fed +12v with ignition. The two-wire solenoid is ground-switched via emissions computer to open/close. Feed +12v to one wire and ground the other to a good ground and it will stay open with ignition.
just wanted to add to those who buy a Chinese knock off carb, disassemble and clean out the ports before putting in to service. I read about it, I rolled the dice and lost. The good news is after cleaning out the filings it is running normal again.
Can you give a link to the carb you bought? I'm so sick of fiddling with my stock carb, I just want to throw something new on it (without having to go into debt).
The manifold studs probably need some corrosion removal, if they also look like that under the nuts. Did you use anti-seize? Did you use any sealant on the manifold gasket, particularly on the intake side? Did you run a die, or thread restoration file, over the manifold stud threads before manifold assembly?
There is a fuel screen before the float needle and seat in the carb air horn. Was it inspected or cleaned? I noticed that that the factory used sealant on the gasket for the air horn, on my knock-off carb, it might be tricky to open, and it probably needs a replacement gasket after you do get it open.
Glad you got it running right. Reading your original post my immediate thought was classic symptom of a leaky vacuum booster. One minute running perfectly, next minute running rough and barely idles. If there’s a hissing sound above the brake pedal, that’s your leak.
I think unless you buy the City Racer carb, it’s going to need work to run right.
You could send your carb to one of the experts on here to see if they can get it right. What issues are you having? Are you sure it’s a carb problem?
i pipe dreamed this up , and it will secure the FJ60 / late Modle FJ40 Fuel Filter in either vertical direction
part #
23921-2FJ60
can use a M8 fastener or a m6 w/ fender washer too ....
comes with qty x 1 part # 23300-38100
