chevy v8 forum
New zealand
hi could someone point me in the direction of a chevy v8 forum
thanks
reason being that i just got a 82 fj40 with a chevy v8 and 5 speed that is heavy on the fuel and has a strong fuel smell
pics to follow
thanks
Check all your lines for leaks, is it carb or fuel injection? Electric or mechanical fuel pump?
Welcome! We need more info and of course some pics. Ask away, this is the best source of info on your cruiser anywhere. There are many Chevy v8 runners here.
yep, LOTS of V8 owners here....lots....
TBI? TPI? Quadrajet? Holley? Carter? Edlebrock?
stock mechanical fuel pump? In tank electric? external electric?
hard lines from the tank? soft lines? return line or not?
Stock tank? Aftermarket? how attached?
sbc thread
Could I hijack this for a minute and ask what bellhousing you use to keep the 3spd trans? I've used early truck cast iron ones, (1950's) but was wondering if some of the later aluminum ones would work. Motor from 78 blazer in 69 fj40.:confused: ;p
3 Speed??? he's runnin a 5 speed. yea... more info please
Another hijack
Maybe we do need a Chevy V8 forum....
Please excuse another hijack...... Anyone running a Chevy 350, low hp engine that knows the "total spark advance" for best highway mpg? I'm running Edelbrock multi-point fuel injection and have the flexibility to change lots of parameters, including timing at various rpm and manifold vacuum conditions. All of my vacuum and mechanical advance distributor stuff has been replaced with Edelbrock electronics. I'm trying to milk every mpg I can out of this thing.
Need advice on total timing advance I should be running at about 2400 rpm going down the highway on level ground?
Thanks....
Don
Thanks....
Don
Mechanical advance set it to 10-12 idle, 32-36 total. Then another 10 or so vacuum. Not sure how fast you want it to come in (curve). Probably not too aggressive for a stock motor. Here's a link.
http://www.rodandcustommagazine.com/techarticles/0604rc_ignition_timing/
V8 forum Q's
If I am buying a wrecked chevy truck for a TBI swap what year is best/easiest to use? I am thinking 94, 95, or 96.
Gary
87-95 were the years when 350TBI were made. 96 they went to the Vortec. I would try to get a later TBI motor if possible.
my Chevy V8 driving husband hangs on "www.coloradoK5.com" :)
I have a crate motor 350 right now with an Edlebrock. I believe it's an earlier year motor. How involved is going from a carb to a TBI and how well would it work on an earlier motor?
It is not very involved and should work on an earlier V8. My engine came from a 79 truck and the TBI is a pretty straight forward install. I will never go back to a carb again. Runs and starts better. Easier to diagnose and work on.
thanks
pics to follow
thanks
Jumper, you still here?
I had raw gas smell and found that the return line from the charcoal canister to the tank was blocked with a puddle of water. Cleaned that line and solved that little problem.
I still have strong fuel smell in the exhaust, but I'm fuel injected so the solutions will be different for you. Carb tuning is maybe what you should research next.
I've heard admission is one of the first steps toward recovery.:D
I run a 79 40 with 90 tbi and get around 15 mpg and have gotten 17 on one flat land trip at 65 to 70 mph
