Chevy starter questions
Portola C.A.
Ok, here we go. 350/400 My starter died the night before a trip went to napa and all they had was a rebuilt starter. It sounded horrible even after every shim combo I could try, it died four days later. On to the new stater it died last night. My flywheel looks good and never had any issues with the original starter making any noise before it died, it was in the fj for a very long time. The oririnal stater only had two connections, because I have an HEI dizzy, the others had three but the parts house said it would make no differance. Am I getting the wrong starter!!!! I don't know what year the motor is so if anyone can figure out my engine codes I would be very, very grateful.
This is what's stamped on the front ot block under the alt.
V1024TJY and C4Z120101
Thanks Jason
Thanks theo, I think the last starter I got was for a 73' so I was way off. Your help is greatly appreciated
Good luck. I didn't think there was any difference from '73 to '78 but maybe so.
It sounds to me like there might be some slight difference in the nose cone which was making the NAPA starter bind. I don't suppose you still have the original starter? Sometimes you can put the old nose cone on a new or rebuilt starter to cure alignment problems.
Flywheel tooth count should be 153 (I think that's it) from the '60s to 1986, when they went to 168 teeth.
shouldnt be too much if any dif in the 70's
might have just had some bad luck, lifetime warranty arent they, no worries
Ok, took the srarter back and the part #,s for the 73' is the same as the 78' I guess it was just a junker. Put the new one in and had to shim the outside .060 to get the proper gap. It sounds alot better but more important the 40 is going hunting this weekend
Thanks for the help Jason
