Pretty vague question, assuming you have a DUI or similar HEI ignition in your Cruiser?My ICM started acting up. Who makes reasonably reliable ones?
Almost any parts store in the country should have one. Either a 4 pin or a 5 I think. Be sure to put the diaelectic grease on the mounting surface.
performancedistributors.com
It's a Chevy distributorPretty vague question, assuming you have a DUI or similar HEI ignition in your Cruiser?
They do, however the more I've looked into it some brands are better or more reliable. The last time I put one in I was lucky and found NOS AC Delco but I haven't found any that were made in the U.S. this time.Almost any parts store in the country should have one. Either a 4 pin or a 5 I think. Be sure to put the diaelectic grease on the mounting surface.
That's one of the brands that seemed to rate high in terms of reliability. I'm keeping that in mind.I've been running HEI for decades in my many sbc's and only had a couple modules fail. I usually steal a module from one of my spare gm HEI distributors. If that's not available, I go to Standard Motor Products for caps, rotors, and parts like modules and such or GM.
Accel was one of the brands I was interested in. Yea, the one inside the cap. Have you used the Accel?I always carried an Accel spare ICM. You are talking about the small one that goes inside dist, correct ? If its bad swap to an LS.
