Check engine light code 26
Anything is possibly at this point. Would a small hole in the intake tube really cause it to run rich?
I would expect unmetered air to result in lean, but the ox sensor may tell it to go rich. What ales you think it is running rich? I have not seen if mentioned ?
How long have you had them for? I wanted to get genuine ones.
Over a year and they keep the motor happy for the OBDII test. They come in a blue and red Denso box and look exactly like the ones I pulled out
This thread just explained what happened to my '94 a few months ago ... it threw a code 26 after I drove it through a moderately sized creek (had to clip the ends off a safety pin to create a jumper to pull the code ... made sure to add some paper clips to my vehicle tool bag when I got home!) ... as others have experienced it reset on the drive home. I'd wondered if an O2 sensors got wet or something and just needed to dry out ... sounds like that's most likely what happened.
Guess I'll have to add some O2 sensor TLC to my to-do list.
I wanted to proved an update. Had new 02 sensors installed Saturday. Had to have a muffler shop do it. The bolts were so badly rusted the pipes had to be cut and new sections with bongs wended back in. Cost $100. I don't want to jinx anything but so far the 80 is running great. Code is gone too.
