Charcoal canister setup help
MAR FJ40
Argyle, Texas
I have a 76 FJ40 and am installing a Holley sniper EFI, hyperspark distributer, coil and ignition. I have the OEM canister setup with a line ran from the bottom port of the canister back to the fuel separator w/ a check valve. My question is where to route the top two ports on the canister. I searched and haven't been able to find the answer. Thanks
pic from mud on canister...
There's quite a few threads on the evap, and the factory service manual is helpful as well: Adding an evaporative emissions systems to a 2f - https://forum.ih8mud.com/threads/adding-an-evaporative-emissions-systems-to-a-2f.1047046/
I believe the bottom is just open to atmosphere and the top is one to tank (with a check valve inline) and the other to vacuum (but with the thermo valve / VSV inline).
Instead of the VSV, I used the Sniper output pins to control an electric vacuum solenoid to control the vacuum port by coolant temp sensor. Basically either enables evap only after coolant temp is up a bit.
That is a nice way to do it. I just used the ported vacuum on the sniper, so that it only enables when rpm rises (off idle).
Thanks for the reply. I must have misread the bottom feed venting to atmosphere somewhere along the line.
So you just run a direct line from the canister direct to the sniper ported vacuum and it's good to go? aka...no vsv?
Factory setup is a hose that dumps into the frame tub so any drips of fuel would drip in there to evaporate instead of onto the ground to evaporate. :meh:
The ported vacuum line goes to a vacuum valve (link below) which will see a vacuum when rpm’s go above idle. That opens the valve and allows the canister to vent to the non-ported vacuum.
So the smaller tube on the valve goes to ported vacuum. The two larger outlets connect to the canister on one side and manifold vacuum on the other.
Great, this helps a lot! Ordered the vacuum valve and I think I have a good idea of the setup now.
Not sure of your TB connections for the vent, but this is how I plan to run mine. When the engine is up to temp and off idle, it will draw fumes into the intake manifold.
The later cans have 3 taps on top to accommodate the outer vent control that vents the float bowl.
I laid out what I believe my understanding is in the pic below....Does this look right? I also have a Holley Hyperspark Distributer if that matters any (no vacuum line connections)
