Center Differential Lock Transfer Indicator Switch Problem
I'm just going to throw this out here, I've been searching for answers and can't find anything. I have a 2000 LC and when I press the CDL button, nothing happens. I don't get lights, I don't hear a relay click on the passenger side, its dead in the water. I ordered the indicator switch for good measures and will install it, but I don't feel like anything is engaging. Any thoughts?
So I did this fix today.
I had the symptom where I click the center locker button, I hear a sound of something engaging but the light never turns on on the dash. When I drive in circles I can feel the diff is locked so the mechanicals were working just not the electronics. I didn't think the light bulb on the dash was dead as nobody uses this thing so I thought it might be the switch. Also, when I start up the car I notice all the lights like engine warning light or ABS light come on but the center diff light doesn't come on, so I found that odd and thought maybe the light bulb went bad but then decided to tackle the switch first before the dash bulb.
I'm glad to say it worked, but it was a pain in the a$ to access that switch.
Some advice:
- Get a 12" 27mm wrench. I don't think anything longer would of worked easily.
- I bent the heat shield above the cat down a little when working on the switch, to prevent it cutting into me, then bent it back when I'm done.
- Lie down perpendicular to the length of the car, with your head pointing on the passenger side's door. This allows you to use both hands touching the switch.
- At first I thought my 27mm wrench was too big and loose as it was not "biting onto" the sensor's hex. Lying down perpendicular to the length of the car and using two hands, with left hand touching the sensor and holding the circular part of the wrench, and right hand applying the torque, this worked best. You cannot see anything but using feel my left hand was able make sure I was able to securely mount the whole wrench into the Hex of the switch. When I didn't have my second hand the wrench kept getting loose and moving around.
- Before inserting the new switch, make sure the electrical pins are "straight". If it's bent you will never be able to get the connector on.
- Electrical connector was hard to remove. I had to "press" it down and the press clip was facing away so you cannot see it. After you press it down and jerk it up a little, it makes a "click" sound and unlocks delicately and then you can spend more of your energy forcing the thing up. If you're not careful the clip will lock again, so just press it down again.
- When I took the original switch off it didn't have a washer that came off. I decided not to put the washer that came with my new switch on, as I thought it might have welded/rusted onto the transfer case surface. I was afraid if I put the washer the tolerance for the switch will be too "high" and not engage...
This video is a good tutorial. I used.
There are 3 switches it appears on the transfer case. I replace the one in the video and in this thread. If you are looking at the transfer case from the front of the car, the sensor is on the 11 o'clock side.
Putting the car into Drive, I press the lock button. And low and behold the lights come one!
And when I press the button again it turns off!
So confirmed it works.
What's the part number on the switch?
I had the same issue, cdl most of the time works but during few minutes of riding on dirt roads with the cdl on, when i suddenly turn it off it won't open again for a couple minutes even if i switch it to low gear, i replaced already all the sensors on the transfer case but still usually it won't reopen again after being turned on for quite some time off roading. Any solutions about that? I'm thinking of replacing the cdl relay which i guess is 89533-60210 but there might be other solution.
Just did this repair in my garage and the hardest part was getting the box end of the wrench on the sensor and loosening it up enough to unscrew by hand. After, it was a very easy and quick fix. All in took about 15 min once I located the sensor.
Can anyone provide me the part numbers for the sensor(s) / switch(es) to be replaced? I do have a 1999 LC100 and the diagram on partsouq shows multiple sensors/switched and I don't know which one(s) to replace.
If your issue is that the CDL works, but the indicator light does not come on, then there is just one switch to worry about.
I don't have the Toyota part number but I used this one my 2000 LC:
Beck/Arnley 201-1788 Back-Up Switch​
No idea how hard or easy it is to get this part in Switzerland but it was very cheap here in the US.
As has been said above, you might just try removing this switch, cleaning/degreasing it, and putting it back.
Thanks for sharing. @DFXR
My behavior is a bit different. I push the button in the center console, indicator light goes on, CDL locks BUT it does not unlock when pushing the button again. So I got stuck few times with center differential locked. After pushing the button dozens of times, driving around back and forth, then it unlocks suddenly.
I want to get it resolved.
Guess it's the same root cause with different behavior than yours? What do you think?
Pull the switch off, clean the contacts and exercise it out of the case a couple of times. It'll take all of half an hour to see for yourself.
I'm with ^ Malleus on this one. Lack of exercise is a free and relatively easy thing to diagnose, and your description plus your temporary solution points to it. Pull the switch, clean and exercise it, and put it back.
So many 4WD vehicles go years if not decades without real engagement, and our 100-series are no different.
Sorry to revive and hijack this thread but you bought a 2004 100 series Land Cruiser off a guy, 1428Mike, how is it? I am his son and I was curious on how it’s been.
Wanted to add my own experience here. All the normal symptoms, locker is working but the dash lights are not...been this way for about 4 years. I was able to get a 1 1/16" socket on the switch with a 10 inch flex handle (1 1/16 is nearly identical to a 27mm). I pulled the switch out, washed it down liberally with brake fluid, and exercised it about 100 times (pushing in and out, and rotating). I reinstalled the switch and viola, dash lights are working again when locker is engaged.
