center diff lock
More traction where Low range isn't required.
If you do the Pin 7 mod as well (CDL switch required), you'll gain full control of the CDL, i.e. able to *unlock* in Low. Especially useful for maneuvering heavy trailers and such.
also, what all do i need, besides the switch itself, and the connector, and what all is needed to be done, mods...things to the effect
That's the beauty; the CDL connector is already there, behind the dash. All you need to do is pop out a "blank" and put the CDL switch in its place.
The Pin 7 mod is well documented in the FAQ. :cheers:
CDL switch + Pin 7 = Good times.
Having complete control of your 4WD system: Priceless :cool:
what advantages would i be gaining by doing so?
I.e: Mud, oops! ***, possibly snow, and sand. Sorry for the three letter word. :whoops:
High wheel speed, say for instance in ***, the tires will spin clean themselves and give you better traction with a fresh, non gummed up tread patch. With sand, you need to stay on top, low range and 9 outta 10, you'll sink. :) Have a nice day.
:D...three letter word...jeez I crack myself up.
damn, it seems to me, that i need to get a cdl switch, does cruiserparts have one, or do i have to buy one from the dealer, i looked around, cant seem to find one
Mine came from cruiserdan, IIRC ~$50. A great source for OEM parts.
https://forum.ih8mud.com/**-ih8mud-com-vendor-marketplace-**/17873-getting-cruiserdan.html
You can also use a emergency flasher switch, with a simple mod. That switch is used in a bunch of other Toyota's. Search will net threads on this.
This information is very well documented in the FAQ....as already mentioned.
You can get the CDL switch from CDan and others, or from Slee off-road:
Slee - Electrical Switches
I linked to them as it has photos and installation instructions. They also have a good write-up on the Pin 7 mod in their technical section:
Slee - Pin 7 Mod for CDL (Toyota 80 Series Land Cruiser)
Again, read through the FAQ sticky at the top of this forum! Great resource.
well, what about the square one, with the rotating thing in the middle that sits next to the steering column on the left side next to the light dimmer and relay for the side view mirror motor, where can i find one of those, ill get a pic later\
Just wanted to say that this thread was very helpful to me. I too am eager to add a cdl switch to my FZJ80. Thank you all very much for the assistance.
anyone know of anywhere i can find a center diff lock switch such as the one i posted up above this, it would seem to be the most convenient for what and where i want it, and i already ahve the blank out ready to go.
