Hi friends, getting ready to install the CCOT wheel well roll bar supports on a 65 titled 66 FJ40 but I have this bracket in the front of my rear wheel wells and not sure how to place the new supports. Any guidance? Thanks in advance - John
nope, that would add nothing structurallyWould it make sense to keep it and weld a plate to it extending under where the roll bar would mount?
Ok. Back to the drawing board. Yes def want to keep the old bracket if I can. Maybe I do the CCOT Bracket behind and then weld a plate to it under where the roll bar would mount like this? Thoughts.I always add a plate under high stress areas like that. Rollbar feet, tow hooks , etc. Usually mine has an attachment to the frame. Sandwiching the sheetmetal top and bottom with plates is better than just using 4 bolts with washers thru the floor. In this situation welding a plate to the stk support is a good idea. I might add a gusset from the stk support extending across the plate . I dont see an advantage of removing the original support and adding the late model support. They are both going to be attached the tub and not the frame. It's not like the rollbar is a pillar of strength.
