Caster correction question
Central Florida
So i'm installing 850J's with L shocks up front and 863 heavies in the rear with N74E schocks. My truck is completely unloaded, no extra anything on it yet. My questions is, what caster correction has worked the best for folks here?
Should go with
1. Slee 3 degree blue bushings
2. Land tank plates
3. Slee plates
4. Man a fre drop brackets
I have an ARB rack and waiting in the garage, i'm planning on an ARB bumper, some sliders, skid plates and an Iron pig rear bumper later this year. Just want to know what has yielded the best results. I know someone out there has done J's with heavies on a unloaded 80.
Below are some of the many threads i read but i can't seem to get a good answer.
https://forum.ih8mud.com/80-series-tech/268805-slee-4-inch-kit-vs-j-spring.html
https://forum.ih8mud.com/80-series-tech/237034-correct-not-correct.html
https://forum.ih8mud.com/80-series-tech/267584-lt-plates-short-5-8-drill-bit.html
Thanks for your advise
your right on the line between slee (blues) and landtank plates. i'm am running heavies all the way around but, i am loaded and and went with the slees.
I would venture to say, install the shocks, springs and get it measured. See how far off you are or aren't to make a better decision on which CC to use going forward. Seems no 2 trucks are alike when it comes to lift and CC, so a CC for one rig may not be correct on yours.
X2 ..
Just for reference I'm runing J on front and 863 in rear with no weight added and pretty happy with the slee caster plates ..
Here are my aligment numbers after installing my front 850J and rear 863's springs. What do you all think would be my best choice to get my truck back right?
Left
Camber 0.2
Caster -2.0
Toe 0.06
Right
Camber 0.2
Caster -1.5
Toe -0.09
Cross Camber 0.0
Cross Caster -0.5
Total Toe -0.03
Well i did not get the alignment done. I just had them put it on the machine and give me the numbers, so that i would know what plates to buy.
Hi finally what method of caster corrector do you used? what are your alignment numbers now?
I am asking because i have the similar problem, I have J spring front and rear not load yet, with slee caster corrector and my alignment number are:
Left
Camber 0.0
Caster 3.9
Toe 0.05
Right
Camber 0.1
Caster 4.4
Toe 0.05
I have a Lexus LX450 and follow the FSM say caster 3* +- 1*, I understand that 4.4* is over of maximum set.
Somebody know how many degree of correction have the Slee caster plate kit?
thanks
thanks
4° actuall I use 'em and with front J and MAF coil spacer ( with only a factory winch added ) I'm in the 4° range my only issue it's my Cruiser " wants " to take to the right a bit ..
The other thing with nice caster it's the PS needs to work a bit more in turns ..
thanks for the info. Maybe I move to the ironman bushing, I guest correct 3* o 3.5* to try to be on 2.5* or 3* on caster.
The camber is out of spec. It should be +1 on both sides. It is not adjustable, so if the measured values are correct, this may be a sign of a bent axle housing. Do you do any sand dune jumping?
Well not never jump yet, and before the lift and 3 year a go the camber 0.2 too
