OK, took my control arms/Slee bushings/Landtank template to a couple of shops this morning, found a local high volume tire/suspension shop which installed the bushings using the template. I was excited, got home, and installed the arms. After driving, I thought it didn't change how I expected.
After looking underneath the rig, at the arms, I found the front bushing has the hole "lower" than center, and the rear bushing is "higher" than center. I can't make out the hash marks, but, am I right in thinking the bushings are backwards from how they should be? If so, I feel dumb for not checking the arms against the template. I was just so anxious to see whether the arms would fit, and if the holes were spaced correctly...
