Caster bushing removal???
San Antonio, TX
Will a 12 ton press be enough to swap out caster bushings, or should I go with the 20 ton??
-Darius Weaver
More it always better.
Whats the price difference? Probably not much is my bet.
Neither will do any good if it gets cocked to the side so I would say that technique and what you are using to press with are most important.
$100 price difference. I figure if I take to dealer, they will atleast charge me 2 hrs. @ $90. Or I can buy a 20 ton one for $240, and do myself, and have a press after the job is done.
-Darius
Took my controls arms and bushings to the local Toyota dealer (small town) and the shop manager let me use their press for no charge
Don't need a press. We did it with a small 3lb sledge hammer, a vice and the concrete floor. Pounded them out, pounded them in.... no problem.
I have done a bunch of them with a 12 ton, but it takes all of the power that the press has and we don't have to deal with rust. If I were buying a press to do them it would be a 20 ton. The press is handy for many other jobs, my favorite job for it is bending metal.
do you really need that much force?? i have access to a 50:1 mechanical advantage arbor press...i was hoping that would be enough. will i need more?:confused:
barrypt5
When I pressed the bushings out of my rear upper control arms and panhard rods so I could powdercoat them, they all took over 10 tons. I was using a 40 ton press with a scale.
If you are running Js up front you could return the press and the bushings and throw in $100 bucks more and get my old Slee Gen 1 arms and bolt them on...no muss no fuss! :)
Sorry, already bought the press(on sale for $189) and got them installed before I read your offer. I figure I'll be ahead just by having the press.
Now to go get the caster readings...
