cargo dom light
Panamá
Website
www.4x4panama.com
Hello all folks .. the problem isn't the light really .. where it's the pin switch that controls this light on/off when you open close the upper tail door . ?
thanks
David
In the upper lift gate latch. To confirm, open it and then trip the latch with a screw driver or other such rod instrument.
I will check it .. thanks for the tip ..
I was looking around and checing and was unable to find the pin switch .. anychance of a pic .. ?
There is no pin that get pressed in, it's actually the latch itself. You have to use a screwdriver or your key works to trick the latch into thinking that it is secured to the lower lift gate.
But remember to pull the handle releasing the latch before you slam it closed or else you will get denied with a horrific sounding slam.
so to check the signal from the latch .. thought I need to look inside of the door for a signal cable ..
Did u have any joy fixing this thing? I'm trying to fix mine but no joy so far.
sorry not yet .. I send my sat searching my rear broken glass and installing it .. along with some Tencha braking problems ..
I will try this weeend ..
