Carburetor ID
Louisiana
Can anyone identify this carburetor on my 81 FJ40?
Thanks, thats it. I was thrown off by the stock air cleaner
If it doesn't say, "Weber" on the castings, it is not a Weber but an infamous knock-off. Probably covered up by the air cleaner adapter.
That has to be tough without a wire to the choke. The chewed-up end of the fuel line is something that I'd investigate further. The air cleaner housing might benefit from some vacuum caps.
It is a weber 32/36 ... not a 38
Thanks. Here are some better pics...looks like indeed a 32/36 Weber, which I assume is not good news for my 81 FJ40.
Its running great and so far no issues with lack of manual choke...but isn't this too small for a 2F?
I'm running a DGV on my 2.4L Nissan 720. I just might run this carb on the 2F in my 40. The thing about these undersized carbs, is they are somewhat generic regarding throttle, just specific regarding idle. The 2F needs more air than a 32/36 Weber can deliver at idle. So you adjust the carb to idle at partial throttle. A couple of minor problems arise with that, one is with ported vacuum, the other is with a consistent idle speed. So, on my Nissan, I drilled a 1mm hole(s) on the throttle plate(s) opposite the fuel entry passages sides. (See the Pierce Manifold YouTube trilogy.) This allows you to run a large idle jet and get your carb at that sweet 1.5 turns from when the idle speed adjustment screw touches its seat. The Weber is a great carb, just not as well received as an Aisan for owners of 40s. You might install an O2 sensor in your exhaust, connected to an air/fuel ratio meter, and tune the jets according to a wide range of throttle conditions. A properly tuned air/fuel ratio is critical for engine longevity, OEM (where are my Aisan high altitude jets?), or aftermarket. A 32/36 series is fine if you are not on the drag strip or having float bowl angle issues with topography--some say the stock carb has a better range on its float bowl at extreme terrain angles. I wish the Weber had a float bowl window. A cruiser fuel pump might be too much pressure? I'd try to run the fuel return line with the kind of pre-carb plumbing on my 720 Z24 because the later 40 has a tank with a fuel return line, and I hate vapor locking in the high altitude desert. I'd install vacuum caps on the air cleaner assembly. There is a cheap, not so good, manual choke conversion for the DGEV from Pierce Manifolds on Amazon, if you don't want to mess electrical, but it is not a smooth throttle-pedal-independent choke operation that you get using the Weber DGV.
