Carburetor de-smog question
Fort Worth
I looked through previous posts and the tech section and was unable to find anything I could understand.
My cruiser had all of the smog equipment removed from it and I have some questions about stuff that whoever did it left open. Can you identify these two hose fittings and tell me if I should plug them up or what?
This image is of a connection that is coming out of the middle of the intake manifold and points towards the firewall.
In this image I stuck the camera down in the engine compartment and pointed it up at the connections in question.
TIA
Eric
The top one is the EGR connection at the carb and the lower one appears to be the vacuum port for the PCV valve. Neither one should be left open or it will cause a large vacuum leak. The PCV valve should be connected.
Is that two pictures showing three seperate openings? You bought it that way??
I'd be surprised if it ran with those open, especially the lower PVC one. You want the PCV system if there's no alternative and at least plug the other with a short piece of hose and a bolt in the hose. Clamp them.
That top one could be the power brake vacuum supply? Your cruiser isn't old enough to have had vacuum switching from 2wd to 4wd.
I don't have a p.c.v. on my 1977 2F engine.(I don't have any smog crap) Should I get one. The vacuum port on the intake is plugged, and the port on the passenger side of the engine is left open. There is no vacuum leak there. What problem can I have without p.c.v. valve?
:beer:
froggy said:
What problem can I have without p.c.v. valve? :beer:
It means "positive crankcase ventilation" and it's not necessarily "smog crap"
You need some kind of sucking ventilation for the crankcase or the pressure made by the pistons pumping can cause oil to be pushed out through the seals. It can cause some really big leaks.
A 'road draft tube' was enough for years - a tube extending down toward the road with a slanted up from front to rear cut at the bottom that would act sort of like an airfoil, drawing out the crankcase fumes and relieving the crankcase pressures. The later 'PCV valve' uses manifold suction, vacuum, to do the same thing.
internal combustion 101
Sorry the pictures represent only two connections.
The PVC goes into the air cleaner and is in tact. The power brake vacuum line comes off of the intake manifold nearest the firewall. Their is another one that goes into the crank case on the passenger side of the engine that is connected to the carb, although it might be in the wrong place.
These other two are a mystery to me.
Maybe you are confusng the valve cover vent with the PCV? The valve cover is vented to the air cleaner on later engines. The PCV is located on the lifter side cover near the firewall and needs to be connected to manifold vacuum (at least on the ones I have seen). What year are we talking about?
You are right I am calling the Valve cover vent the PCV. Figured that out shortly after posting the message.
I have the PCV connected to an outlet on the top of the carburetor. The Power Brake booster is connected to an outlet on the top of the intake manifold near the firewall.
This appeared to be the way the hoses went because they just sort of naturally fit there. It is possible that the PCV AND the Brake Booster are completely in the wrong place.
I also found a short section of hose stuck down in the engine compartment that obviously had a bolt in it at one time. I assume this was there to clog something up.
Here is a pic where you can see where the PCV is connected and sorta where the brake booster is connected.
Default.aspx
At Autozone I bought various rubber fittings made by Vacu Tite to plug both EGR pipes, and unused vacuum ports. Get the smallest ones for the vac ports. I bought a couple of big assortment boxes as well as some single packs. Or, you can plug it with a short piece of vac hose and a golf tee; this does not look as clean though. I run my valve cover vent to a hose with a filter on the end of it, also from Autozone (a little filter they sell to the rice racers for some reason or another), rather than running fumes back through my engine. I do the same with PCV, but according to PinHead it needs a vacuum source to vent the crankcase; though I thought it had enough positive pressure from the fumes to vent on its own. Maybe not.
This is a 1978 FJ40.
I'd happily plug those things up, but I am trying to find out what is what and which is which. It is very clearly out of wack at the moment as I have to run the engine Full Choke and there is a very loud sucking noise coming from the carb area.
you've got a very large vacuum leak. probably the PCV that Pn Head was referring to earlier
Well I don't have a charcoal canister and I have that line hooked up to the PCV.
Should I just cap that one off? Or should I find a charcoal canister and figure out how to hook all that back up?
By The way Thanks Robert! It would appear that I do indeed have the PCV going to the wrong place.
The charcoal can is a good thing. Yes, i would try to find one and reinstall it.It will cut down on gas fumes a bit , or so I have read .
Thanks for all of the help guys. I was hoping someone could quickly spot what was what and say Plug this, connect that and I would be done with it until the time comes for a TPI V8 to take the 2Fs place.
