OK - have another thread here but got some more feedback from vacuum readings. I started it up with choke on and it idled fine. Initial cold temp reading on the vacuum gauge was around 16. As it warmed (with choke still on), the engine RPM increased slowly (as normal) and the vacuum reading slowly rose to around 20 as the engine came up to temp. It hovered there for a few mins with choke still on then, as I was watching the gauge, the engine suddenly lowered in RPM and the gauge dropped to around 16 PSI and stayed there.
When I reved the engine, the needle went up to 24 or so as it should but then it settlled back down to 14 (lower then before) and the idle became even more rough and seemed about to die.
I assume there is something in the carb system that adjusts as the engine warms. Trying to figure out why it runs fine at cold idle and as it warms then vacuum drops and idles rough after warm.
Note that there was never any erratic vacuum readings or violent movements on the guage as would indicate other problems.
I guess I have more reading to do.
BTW - Am I the only one who reads about 3 hours for every 15 mins of wrenching? Or is this just the norm for a newbie?
AndrewT
AndrewT
