Carb Tuning Question
Just rebuilt my carb, installed it and somehow it runs! hah
two questions for yall to complete this long journey:
Can you adjust the idle mix screw with the air intake (just the top off) while its running ?
I got to the idle speed screw, just worried the vacuum wont be correct if the air intake is not sealed. I watched the video on youtube but thats an FJ40
second the high idle screw is for the choke when its fully closed right ? what rpm should this be at ?
My idle is around 1k right now and need to get it down about another 300 rpm, thinking i need to lean it out a tad and get the idle screw set
I know lean drop blah blah
I've never been able to access the idle mixture screw with the air cleaner on. I usually take the air cleaner assembly completely off the carburetor and set it aside with the vacuum hoses still connected (air injection hoses have to come off however). I think it is worth it to do the Lean Drop method or something similar (optimizing intake manifold vacuum at idle). After bench setting the idle mixture screw counterclockwise two turns from seated, I find I actually make the mixture more rich to get the correct fuel:air mixture. This will increase the idle speed, and then you back off the idle speed screw. It is an iterative process.
I found this procedure in the 1986 Land Cruiser Maintenance Procedures Manual. I've never actually tried this:
When I've completely torn down my carburetor for a rebuild, I have done the procedure below, which comes out of the 2F Engine Repair manual. It does require a special tool, which is a piece of wire that is 1.3mm in diameter for measuring the gap between the the primary throttle plate and the primary bore wall when the choke is pulled out.
Yea theres no way to get to the idle mix screw, Ill give it a shot with the air cleaner off.
So it sounds like with choke fully out RPM should be around 1800
thank you for all this
You can access the mix screw with the Air cleaner on if you use a long skinny screwdriver. This is what I use LINKY
However, it takes a bit of work to lean over the fender and have enough light to see where the screwdriver blade is, so what I do as an alternative is remove the AC and plug all the appropriate hoses per the FSM and then use a small 5.5oz empty cat-food can with about 5-10 small holes in it to simulate the restriction of the AC. That size cat food can fits perfection over the carb.
I use the A/F meter for the rest of the tuning. Works great.
My 60 high idle with choke full out is around 1800. Last click of choke (when pushing in) idles around 1100. My normal warm idle is about 750, maybe slightly higher. I find it starts a little easier with slightly higher idle and a little more oil flow can’t hurt things.
Yes you can adjust, you just do it from the firewall side with a very long screwdriver. Is it absolutely necessary? No.
Why? Engine vacuum is present below the primary/secondary butterfly therefore anything above is atmosphere. The slight reduction of inlet air at idle won't be affected enough because you're only tuning for air at idle. (This is why fuel injection is so smooth, constant adjustment all the time).
What is important?
You didn't note vacuum so make sure your vacuum is above or at 20inches at idle if at sea level up to about 4k feet of elevation. Therefore make sure all of your vacuum equipment is functioning correctly, timing set to factory or slightly more if EGR/Air Injection has been removed and plugged. Then tune again.
Lastly, verify needle is rock solid on vacuum gauge, if not, readjust valves until it is. Readjust idle mixture/speed again if changes made.
Regarding Choke speed, you don't need any special tools, see below:
1. Once the viscous fan has turned off, set your fast idle speed with choke fully closed (verify on choke itself you didn't screw up during rebuild).
2. Locate choke adjuster screw on carb and set to 1800rpm (use a handheld tach for simplicity).
3. Set speed to 1800rpm which when the fans are ON, will settle around 1200rpm.
I finally got myself what I hope is the magic long flathead screwdriver for adjusting the mixture screw with the air cleaner lid on! Home Depot had one that looked about right for around $5. I'm unreasonably excited about this.
Your results may vary, but I'm able to do it with the long driver by having the driver on the firewall side of the Air Cleaner, and looking at the Mix screw from the radiator side and using one of those long, thing LED lights (from Harbor Freight) laying near the air rail, so I can see where the mix screw is...
That's exactly how I've tried it many times, I've just never had the proper tool.
I'm tempted to screw up my carb this weekend just so that I can dial it back in as an excuse to use this thing.
Also, this helps me, I use a sharpie and mark a thick line across the top of the screwdriver, so at a glance, I can see if I've moved the mix screw a 1/8 turn, etc. and helps to remember where it was before I started tinkering :oops:
My PO drilled a ~3/8” hole straight through the air cleaner housing, directly above the mix screw. Then he stuffed a short piece of fuel hose in the hole, to seal it while still allowing pass-through for a 9” screwdriver. It does not interfere with the filter. 16 years later and it’s still pretty handy.
That being said, I’d try any one of the suggestions above before drilling a hole.
(Same PO drilled right into the roof to mount a Yakima rack)
