carb question
Vehicle: 78 fj40 with 2f
Background: I am rebuilding my carb in an attempt to correct a problem with the idle circuit. The engine won't idle unless I have the choke closed a bit.
Question: Are the venturis in this carb supposed to be the same? The fsm indicates that there should be one triple and one double venturi. The attached picture is what I found inside my carb. Could this be causing my idle problem, or is this correct as pictured?
Other info: My cruiser manufacture date is October, 1978 but my carb appears to match the 8/77 and earlier photos from the sor site.
Thanks for any help!
Patrick
The smaller is the primary.. larger secondary.. you can hold one upside down and see the diameter diff in the tube size (marked in red circles), or blow through the bottom tube with you mouth and you can feel the difference in restriction....
Thanks grant5127 for the reply! I checked out the two venturis and they are identical. I measered everything with a dial caliper, checked the size of the hole through the end of the tubes (5/64" drill bit shank just fits) and the air restriction feels the same when you try to blow through them. Do you think I need to get another venturi? Any idea if the ones I have are the larger or smaller? You have answered some of my newbie questions in the past and really helped me out. I really appreciate taking the time to reply!
Can you could post a pic of them up-side down with a good shot down where those tubes are?? usually you can tell by the wall thickness of the tubes which is smaller....
I have a disassembled '78 carb (April 78) and the primary and sedcondary nozzles appear to be identical by everything I was able to measure. Never the less, I marked their primary and secondary locations in case there is some internal difference that is not obvious. This is unlike other years, where the primary and secondary nozzles are different. If I had to guess, I would pick the one on the left as the primary, because it has more carbon on it than the other one. My experience is that the more time you spend paying attention to where thinngs were located during disassembly, the more likely you will succeed.
The idle problem is due to an incorrect idle air fuel mix. You have to pull fuel out of the main nozzles by applying the choke in order for it to idle. There are several possibilities: Manifold vacuum leak (below the throttle plate). Idle fuel cut off solenoid inoperable. Plugged idle circuit. There is nothing in the pictures that would readily account for these possibilities.
Maybe Jim C or Mark A will chime in on this as they have more experience with these particular carbs than I do.
Good photography work, Landlord! they appear to be the same.. I would reassemble in the correct order and see how she runs... just a good cleaning may have solved the problem.....
