Carb help
I was kind of hoping that wasn't the case as it sounds a little intimidating to adjust the valves. I'll have to read up on that.
Going slow it'll take maybe an hour. Most time consuming part is getting the aircleaner off. It really is not a difficult job.
No, it's not. And it really is something you have to get good at. Do you have the hand crank? I find it really helps. Not absolutely necessary, but helpful.
Ok...got Petronix ignition and was going to put that in before you guys told me to adjust the valves. Couple super interesting finds...spark plugs are all different as far as carbon build up (pic...top to bottom is the plug that was in 6-1), etc. After we (we being my kids) got the valve cover pulled, there are a couple rods (wrong terminology) that are super loose and one that wasn't connected at all (see video).
Here is my problem...I can't rotate the crank at all (@Pighead...I don't have a hand crank). I pulled the spark plugs and thought I could pull on the belt but it's not going anywhere. Any suggestions without the hand crank tool? Once I get that, to find TDC on the 1st cylinder, I'm not super sure what to do.
After the valve adjustment, I'll add the Petronix then check for vacuum leaks.
@GA Architect I tried that and it just goes forward and back...it doesn't advance the crank.
@Dizzy when I originally (before this thread) started the engine, it would have a little white smoke on start. After i worked on it (starting this thread) there is no more smoke. I think when I adjusted the timing it fixed that?
Those plugs look funky. I couldn't imagine that the valve stem seals are decent, especially on number 5. Nothing to worry about, doable.
Some folks can turn the engine by the ring gear on the flywheel with the inspection cover off. Also, there are homemade bars for the crank nut on Mud. It is basically a 1/4" all-thread threaded perpendicular into the end of a bar just behind the front of the bar. The 1/4" all-thread protrudes a bit to grab the face of the nut. You can also buy a hex socket, but you have to move the radiator to get it in there. Pulling the belt, while grabbing the harmonic balancer with leather gloves, and no plugs installed, works for my worn-out 2F. Doing valve lash is best done after you deal with the carbon, which is probably the valve oil leak. I realized this after pulling the intake manifold and shining a light on the valve stem (with the header still bolted in on the front and back). There was just too much oil entering the combustion chamber to maintain good spark.
If you are pushing in 4th and see no engine(flywheel) rotation, make sure your transfer case is in 2 hi.
Easy way to find compression stroke is stuff a wad of toilet paper into #1 plug hole. Obviously not stuffed into combustion chamber. Push rig until TP makes a POP! sound. Then rock back or forward til you find TDC mark on flywheel. After adjusting corresponding valves, repeat in hole #6
looks like it was running on two cylinders. Good news is it runs👍
I was going to say the engine sounds whispy like it has a burnt or stuck valve, and then I saw the video of the pushrods. The one that is just flopping around indicates a stuck valve. This is most of your issue.
Light taps with a hammer on top of the valve may free it up and allow it to return to the closed position. Otherwise its off with its head!
Got it to TDC...I put it in 2H (didn't have it in 2H before) and got it to rotate. That's the good news...also, the other valves badly needed to be adjusted...but I think that 2nd exhaust valve is stuck. I tapped lightly with a hammer and it didn't free up. Any other ideas to unstick that? Should I run the engine to adjust the other valves while the engine is hot?
Hopefully your stuck valve is just carbon buildup...
I am a fan of the Seafoam down the carb treatment.
(Engine running at fast idle, dribble Seafoam down the carb, keep it running until exhaust clouds dissipate) try unsticking valve again...
Adjust all the valves you can while warm.
I'd do a compression check before anything if I suspected a stuck valve.
Adjust the valves on a warm engine with the engine off and the battery negative disconnected.
Fellas...thank you for everything. Adjusted the valves and started her up. That stuck valve unstuck immediately...adjusted the valves after running the engine for a while and getting it hot (was even able to adjust while it was running in addition after I figured out the TDC method). It's like a totally different vehicle. It's quiet...some would say it sounds like a sewing machine. Drove it and no more issues. And, you guys are right...the valve adjustment is not hard...not sure why it sounded intimidating to do the valve adjustment.
Still going to put the Petronix in there and check the vacuum...but it runs way better now. Thank you guys!
👊 Well done sir. Hard to kill these tractor motors. Can you take it for a test drive before Pertronix? I'd be curious what figure out your hot vacuum number now and then after Pertronix.
Now you need to start planning an in cab vacuum gauge so you can monitor the valves.
Am I the only one who will spend more time doing oil-splatter laundry, and engine bay clean-up, after running it with the valve cover off, then actually servicing the vehicle?
