Carb diagnosis, rough running?
Utah
Website
cruiseroutfitters.com
So my Cruiser officially hates me the last couple of days... (2F, with Aisin carb, 76' era)
Runs great 99.5% of the time...
But then all of a sudden, it will fall flat on its face... runs super rich, idles rough, and refuses to gain any RPM's especially when it has any load present.
Now heres the part that sucks, I am not a carb guy (I send them all out) but I have been into a few of them over the years. But, as soon as I get to some place to pull over and check it out... By they time I get out of the vehicle, pop the hood and start to mess with the carb. The problem goes away, it will run great for a couple of days... in fact it hasn't done it for several days (havn't driven it alot)...
Any quick ideas before I tug the carb off and send it to my carb guy?
Anyone think that it could be a spark issue?
(New plugs, cords, FJ60 ignitor/coil/dizzy)
Thanks in advance...
PS... My truck hates me this week!
Happened to me once. The float was sticking DOWN, causing gas
to flow into the carb at full flow, dumping into the engine and
causing a ton of smoke. The float would then rise on up and
the problem would go away. I bet a leaky float would do a
similar thing. Is this possible?
Yes it certianly would do that.
The smallest little piece of trash inside the carburator can cause all sorts of headaches...
WORD. :)
Thanks all!
PS... I got out right when it started doing it and took a quick look at the sight glass... it was normal.
That is fine and all,
But looking through the sight glass will not tell you if there is any little pieces of junk in the float bowl, jets, or any other areas...
Carefully remove the top of the carb, and have a look-see inside, under the float....
Has it been adjusted recently. I would first clean it using carb cleaner, run some BK Fuel system (NAPA) from the gas tank and make sure its propoerly adjusted. Here is a link to an easy carb adjsutment method that I used that was created by Treeroot and IDave. It runs much better now.
https://forum.ih8mud.com/showthread.php?t=26635
Have you replaced the fuel filter?
If that doesn't work, I then would begin focusing on the inside of the carb.
