Can't get Cats off!
Hey Guys,
My cats need to be replaced, or gutted, but I can't get them off my 94'. I just got it back from an exhaust shop yesterday who told me the Magnaflow 94004's I bought won't work, and they can't even get the old cats off due to the location of the bolts and the fact they are rusted. There is so little room to get tools on top of the flanges, I can't figure out how to remove them.
Can anyone with experience removing these help me with what worked for you? I've had 2 shops now tell me they can't do the work.
Thanks,
Chris
Hey Guys,
Thanks,
Chris
If the exhaust shop can’t do the work its really time to find some better shops. Most places want to take the easy route of hacksawing the cat off and rewelding it gutted or welding the new one in place without flanges. Your location and if vehicle inspection is present will help us give you a better recommendation.
If I was in your situation, I might want to reach out to @OTRAMM and see if they are interested in building the 93-94 complete exhaust. The one they built for the 95-97 is impressive. This would maintain the ease of assembly and disassembly - but not everyone needs that. What works best for you might not be what I would pursue.
I'm not required to have emissions since I've surpassed 25 years, and I'm in Georgia. I honestly do not know how you get to the bolts on top with tools. I've gotten 3 of the bottom 4 so far, but that was a couple hours worth of work.
The shop could have cut them out, but said the Magnaflows were too big. They also said they did not have a welder that would fit into the small space to get on top.
I have a 93 and I’d have to take a look at what bolt is giving you/them all the trouble. Yeah as long as you aren’t in atlanta you don’t have to worry about emissions in GA. I’ll get back with you later when I get a break.
I was able to cut the bolts holding my cats in place with a dremel and hacksaw in a parking garage one night. I would loved to have had access to a muffler shop's tools at that time.....
I hear you can use the tip of a pen.
  • Like
Reactions: sxp
Long extension and you can reach all the top bolts easily. I removed mine and cut off the flanges. Then I welded pipe between those flanges and bolted them back up. Don't need cats on a 94 unless the smell bothers you or you need to pass emissions.
I wouldn't say easy. I've tried extensions and the socket won't seat, and a couple of bolts are so rusted they are out no longer the same dimensions on the heads so sockets and wrenches don't fit perfectly. I've stripped one or 2 already. How do you "break" the bolts?
Put a socket an one end a wrench on the other and start loosening. It will come loose or the bolt will snap. If they come loose awesome. If they break just get some new bolts and nuts and a few washers. You will need the exhaust flange donuts as well. Odds are they will fall apart when you remove the cats. I'll post a picture of my cat delete when I get home
I know this is of no help, but that exhaust shop sounds like lazy useless idiots!
Find another shop!
Here's a pic of my delete. Was easy to do. Bought the exhaust pipe at orielys.
Yeah, that shop said they wouldn't make those for me. I guess I'll keep hacking away at these bolts!
They won't make them for you but if you can get them off and know anyone with a welder they can fix you up. To be honest it sounds a little annoying without the cats in my opinion. May be worth replacing them or putting a resonator in their place
