Build Canguro Racing's Monica
Prep time! Both diffs and axles fully disassembled, inspected, resealed and assembled. Shocks fully rebuilt. Drivelines services and installed. Next up tackle the assembly of the front suspension and steering.
Outstanding work,
How long are those coilovers and bypasses ? I am planning on doing the same rear end job on my LC200 Project.
I am guessing:
2.5 x 14 inch coilover
4.5 x 16 inch bypass
Please do correct me if I am wrong.
Outstanding work,
I am guessing:
Off the top of my sleepy head, that sounds about right.
Strange questions of the day. Can you run an aluminum driveshaft ? Have you damaged a rear axle housing ever? What is the next race?
No, shafts must be OE
Yes, that is a complete replacement read housing we built/installed before the 2017 Baja 1000. This one has some damage that we keep nursing with 1.5 diff gaskets (damaged diff mount flange from rock hits). The last housing was bent presumably from the same jump that wiped our oil pan and @dmc 's back :D
What are the penalties got getting caught cheating?
As in violating tech rules? Could be a time penalty, could be a full DQ
What brake rotors do you run? I assume stock calipers?
Tell me about Remmen, good prices, but I've never heard of them.
New player on the Cruiser market with a history in performance brakes. This 200 will be a fantastic test case and we'll be retailing them @ Cruiser Outfitters
Yes , the tech rules. We have lost a few wins over the years in weekend warrior level circle track racing and have gotten to just writing it off as the cost of doing business. Many years ago a racetrack kept our flywheel. The guy I help sets the standard on what he wants. Running up front is usually the over riding theme.
Best I have of the exhaust handy on my phone and a tongue in cheek photo of the skid plates. I know I have photos of them but they're probably on my home pc. I'll look tonight.
This stuff is just awesome ! Thank you guys for posting this content it inspires me allot.
I am really curious how well does it sock up those jumps and large impacts ?
@cruiseroutfit
Second question: Do you guys run body spacers to clear 37 inch tires, or just heavily trim the factory bumper ?
Correct, its a 3-4" spacer, I'd have to measure again to recall :D
Awesome, thank you very much for your time.
The front coilovers, I can tell they are a 2.5 with a 10 inch stroke dual rate.
Do you guys cut through the factory shock tower and wield a mount further up ?
Or do you wield a whole new tower ?
Is the lower control arm mount same as factory or also modified ?
Thanks a bunch!
