It's purpose is to slow the door so it doesn't fling open. It is broken so it is doing no good now. If you don't want it you can drive the pin out and remove it. But I would replace it. $0.02
I think I can trace the issue back to a time I was off camber on a trail and had to jump out to clear logs. The door flew
open, hyperextended to a small degree and indeed creased the fender. Seems to have gotten worse in the past few weeks.
It’s called a “door check”. Besides limiting the ultimate angle that your door will travel to, it acts as a brake so the door won’t fall closed on your delicate fingers. They are cheap and available.
I broke mine & hyper-extended the door in the process - replace it before you spend the time & energy I had to bending back the door hinges & luckily found a black door (fender still has its’ crease, the door got one on the skin too).
It’s a $10 part that saves an easy $500 in damage.
They say he’s gathering dust........uhhhh, curating a Landcruiser museum now.
It’s just the plastic arm you pop the rivot & undo the 2 bolts.
It may have been more than $10, but it was chump change to this poor guy, so it had to be under $25.
Try Rock Auto??
BTW, it **sorta** holds the door open, but primary purpose is to keep from wind or parking on a angle (or backing up with the door open & catching a root with your door, springing the arm) - from swinging the door beyond the hinge limit.
