We are bringing this with us to the Outer Banks as a support vehicle:
Is it camping if you get to sleep in air conditioning?
Nothing wrong with a little AC. Lol took my portable AC unit and put it in the trailer to test it out. didn't leave it on long as it got cold quick. Once the RTT is on top with the annex room installed I am curious to see how it does.RVs are ROUGH to move around :\
Oh yeah. That was literally just tossed in there for test fitting purposes.recognizing that it's not permanent as installed, Im going to suggest that the hot air output of the AC unit not be pumped out directly under the trailer like you have it.
I noticed yesterday when i was getting my battery system operational, my aircon ran slower, less efficient, and a bit noisier (electrical noise) while on the 1500 watt modified sine inverter vs straight ac current. I assume a pure sine would theorhetically be closer in waveform than a modified. I was a lil bummed that it took down my batteries quicker than i anticipated....or i was running them a lot longer than i thought i was....ya kinda lose track of time doin stuff
My teardrop was one of the first rustic trail models to use an inexpensive haier 5000 btu window unit for ac. they had been using an expensive climate rite external unit, but many have failed in a very short period of time.
If you can come to the triad dinner tomorrow night, I'll have it there
You're baiting me, right?
Anywho, If they are Group 31's that puts you close to about 200 AH of storage, of which you "might" be able to get 80% out, so about 160 AH of "real" storage.
Invertors are fairly efficient ..... generally above 90%. Let's call it 90%. That leaves 144 AH of usable storage.
At 650 watts (i.e. nothing else running) the A/C will pull 54 AMPS DC!!!
One catch ... pulling large amounts of current from batteries, even lead-acids, also causes the battery to be a source of loss (internal resistance) and it loses capability.
All told I'd give it a little more than 2 hours.
That said. Congrats on the trailer approval! Insulate it well and this will be less of an issue.
... Not as cheap as Steve's Haier is - but I didn't have a good spot for the butt end of an AC to stick out...
Um, that's a 220v split system. It's massive.
You'd only have a small hole in the front, but you'd also have this massive compressor mounted somewhere as well as a 220V generator whirring away...
You've seen my setup for AC. Portable, removable (for the fall/winter camping) and cheap. Not as cheap as Steve's Haier is - but I didn't have a good spot for the butt end of an AC to stick out...
