Camber Adjustment
Annapolis, MD
I recently had my 80's allignment checked because the front left wheel tilts in at the top. Its to my understanding these trucks have non adjustable camber, so how in the heck can I return the specs to a stock setting. Are there any kits on the market to correct this? Please help, the situation is driving me mad!!:mad:
New trunion bearings, or a second opinion on the alignment. If the top really is leaning in, the trunion bearings are probably toast. The only other way for that to happen is for the axle to be bent. Time for a knuckle job.
-Spike
Moe3, I noticed the same issue with my recently acquired '94. Right now, I am rebuilding the rear end and noticed the bearing preload was loose when I disassembled. I am hoping the front camber issue is due to the same. I've had a lot of straight front axle vehicles and have yet to find one with a camber problem that couldn't be fixed with new bearings. Keep us posted with your findings...
it can also be worn spindle bushings, but it would seem to be the bearings if extreme.
I can't imagine how worn spindle bushings would affect camber...? The axle stub doesn't support the wheel.
Not sure how I overlooked wheel bearings as a possible culprit- I get tunnel vision when it comes to trunnion bearings. Most of the ones I've seen were bad (high mileage/ little or no maintenance), so I have a 'thing' about them I guess. :D
-Spike
you can get offset king pin bearings, for castor or camber adjustment, we normally set the front ends up with 35" + tyres with 1-1.5 deg neg camber, which greatly improves handling.
However I've never seen or heard of these being in the US. Has anyone here seen these in the US?
My bet is on either loose knuckle studs or loose wheel bearings.
