Caliper bolt hole stripped
MT PLEASANT SC
The threads in the steering housings for one of the caliper bolts is stripped. Any suggestions for a good fix or do I need a new steering knuckle. The others three are fine. this is a rebuild that the PO started.
Helicoils are stronger than the starting metal.
Another hobby is restoring old Caterpillar crawlers. I've installed probably 70 Helicoil over the years and they work great. You don't have to drill a large hole to re-thread for the helicoil. Sometimes you're working on some part that doesn't have a lot of metal surrounding the threaded hole.
Helicoils are good but keenserts are as well.
