Does anyone have HJ cable lockers in an FJ60? If so how was the install and where did you mount the cables in the cab? Last but not least how do you like them? Pictures would be most helpfull!!!
vtcruiser has a build thread int he expidition forum. check it out.
Here's the stock setup, first the controls next to the driver's seat, and then the able mechanism underneath:
That is exactly what I was looking for- thank you. Do you have any issues whatsoever? Or do they operate as flawlessly as advertised?
No issues at all. Their only drawback is the difficulty and expense of obtaining them in the first place. Install is no problem, basically bolts right up. I had to modify the RHD mechanism to work on LHD vehicle, but it wasn't complicated. The set up is rugged and overbuilt in the usual Toyota fashion, and the fact that you can really feel the positive engagement of the locker as you're pulling the handle is really a plus. Let me know if you want any other pics of cable routing or anything.
Bill
Correct, pulling up on the front locker also engages the rear locker. The rear can be locked by itself.A revival.
I'm thinking it should be possible to engage the front locker individually from the rear locker.
I seem to remember a tab somewhere, pulling both on if I only pull the front locker on.
I'll dig into it next time I lube the levers up ;p
For about a year and a half, I used 2 of these chilkat locker actuators (http://www.chilkatdesigns.com/E-Locker.html) with good results. Super happy with them.
