Cab and Engine Compartment Volume for Fire System?
jaymar
SoCal
Looking at fire suppression systems and need to know volume of cab and (separately) engine compartment (without engine). Not seeing these figures online--just cargo space behind front seats. Anyone have a source on this info?
Thanks for any help!
I very much doubt we have this information available to us. In terms of fire suppression systems, are you trying to use the 80 as a fire truck, needing to calculate how much water etc you can haul, or are you trying to suppress a fire in the cabin and the engine bay? If it's the latter, I'd be curious as to why. My 80 very seldom catches fire.
Just measure L X W X H and get an estimation as a rectangular cube. Or I guess that is what I would do. :) Then post it up here so I don't have to do it!
Figure I've seen for cargo space with third row removed and second row down is 98.9 cubic feet.
Cabin, engine bay, fuel tank area. I figure it's better to have a fire suppression system than not. Handheld is one thing, but for installed system you need to know the total air volume in order to determine how much extinguishing agent you need to put the fire out as quickly as possible, because that happens at a particular % concentration in relation to air volume. Too little agent and the fire keeps going. The agents are also toxic at certain concentrations--so you don't want too much...
My 80 very seldom gets in accidents--but that doesn't mean I don't want seatbelts...
Yep that is what I did, a mental estimate of the 3, multiplied and slightly over estimated since it is for a fire system and more is better than less. lol.
have you actually gotten to a point that you can't find anything else to buy except a fire suppression system for your rig "just in case"??
I hope you rig is decked out with some other really sweet s*** first. Armor all around, rack, RTT, Awning, minimum 37" tires, machine guns (for the zombie apocalypse), and at LEAST 3 extra cupholders (I highly reccomend BH3D). That's just me though. lol
Seriously though, more power to you. What kind of suppression system are you looking at? How is it triggered (heat, optical, manually)? Is it armed at all times or just when when the truck is running?
Any fire you can't put out with a good, full fire extinguisher (i.e. a fire that would need actual, real fire suppression in the engine bay) is probably one you should run like hell from. It's worth noting that 1) the engine bay is not sealed, so that makes it harder to estimate. Your suppression gas/chemicals are going to hit the ground real fast, and 2) I would not want a built-in asphyxiation system in the cabin. I can run from fire, but with hypoxia, you'll never know you're dead.
I'm thinking on at all times, manual and thermal triggers, clean agent, maybe two tanks to avoid long line runs and hit only one area if need be. Halon beats the hell out of everything else, but is costly and has temperature limitations in desert environments (depending on mounting location). Oh--and this has gotta be good for an insurance discount...
You are very likely to die if the fire suppression system goes off in the cabin and you can't or don't get out. If you crash the truck, roll it, park with the door too close to a wall, and the system goes off, it's over. I don't think they're giving you a discount on your insurance for this.
Good dose of Halon will kill fire in under one second. Good point on #2--but one could say the same of a handheld in the cabin. As to running like hell--that assumes you can run. Most likely scenario would be fire after crash, so running may be out.
I have to agree with @math on this one though, You will easily choke to death in the cab if you are in there and the system goes off. It will be a headache to keep up with the system as well. The engine compartment would be a hard one to tackle. I imagine the cost of repairing something on the truck from fire damage would not be much more than the overall cost of a fire suppression system when you factor in upkeep of the system and everything.
Get a Wits End fire bottle holder and a fire bottle and call it a day.
This is where volume comes in. The concentration needed to kill a fire is (I believe; still researching) lower than the concentration that will kill you. Making it rather important to know the cabin volume (and also have a way to break the windows).
it's a stretch at best to say that you will be in an accident that engulfs your truck in flames and your only saving grace was the fire suppression system you installed. just sayin.
WE holder and 2.5# halon on the list. :)
True enough. Then again--what's an engine rebuild cost, $20k?
This is true. Vehicle fires are unlikely.
And if you get that concentration wrong? We're eye-ballin' the volume in the first place. And how fast the gas disperses into the rear quarter panels, and the headliner, and the interior trim (which would cause the concentration to drop, so you'd need a higher concentration initially, or a longer release time) etc - all of which impact the instantaneous and final concentration of halon in the vehicle. This is by no means an easy math problem to solve.
Respectfully, you seem like a good man. While this is way, way more creative than just piping the exhaust into the cabin, it stands a chance of producing the exact same result.
not a rebuild. For $20k, you could swap in a different engine all together. which should be added to the list of things you can do before you worry about fabbing a fire suppression system into your truck, lol
I had a Pegasus foam/water suppression system on my 68 Camaro. Never used it but I've seen some nasty and QUICK vehicle fires so it was never a question of it. I bought a similar system for my LX but never installed it. Instead it sits in storage because I could never make a damn decision.
BTW, as far as my mounts are concerned, I just placed the PO this morning to run another batch of both sides. ;)
Ha. After feedback here (yours included) I'm thinking to stick to handheld for cabin, system for engine compartment and maybe fuel tank area (though the latter also has challenges, like off-road crud buildup and submersion). Of course, this presumes one is conscious and can reach and operate the handheld after whatever-it-is-that-probably-won't-happen, happens.
