Buttercup the Beast
Heading to napa.
You can get rid of those universal radiator flex hoses by using Gates 20416 for the upper and use Gates 20573 for the lower hose. A little trimming might be required. It makes for a cleaner look.
I was getting some wear on the front tires so I checked the alignment and it was almost an inch of toe in so went with an eighth toe in and she’s driving much better. I switched up the 33’s to Montina putting the worn tires on the back and put 31’s on Buttercup. Transformed the ride of Montina with the 33’s so will keep both set ups for a while.
Monte Carlo calipers, 1994 apparently (info on page two). Ya gotta love Mud! Additional info on page one of Rusty Pumpkin also.
That steering wheel is rad!
More pics please 🙏🏽
Try boiled linseed oil, it goes deep and you can keep adding thin layers as time goes on. Real purdy.
That steering wheel is so boss.
LinSpeed oil for gun stocks is the best. Apply when oil and wood are warm the first time for best penetration - finger dunks - rub it in until it doesn't take any more. You can buff in second and perhaps a third coat with old rag - dispose the rag properly properly to prevent fires. light scotch brite to remove any clumps of dried drips,
Linseed oil yellows so much compared to tung oil. I also dont think you can build coats as heavily either.
Both products will require many many coats.
Skip the scotch pad.
#0000 steel wool will be the hot ticket for a finish that is really nice to the touch.
Not to start a pecker measuring contest, but I've been a cabinet maker for almost 30 years and not talking completely out of my ass
My dad and i used to make custom hunting knives and we used tung oil on the rosewood and pecan handles, also used the steel wool between coats and to shine it up. Looked nice and still have a few examples that are holding up fine.
I used to do finish work at a reclaimed furniture company and we used spray lacquer with 220 grit sanding between layers. I hated the smell but it looked beautiful. I’ll probably go that route for a deep glossy finish.
