Rohitash....I will be coming to California in a few days....if you need me to bring any thing let me know and I can transfer it off to you or to someone who can get it to you.
-o-
-o-
where are you buying your replacement rings? I don't see them specifically listed in the online parts catalogs.
I've gotten them from lexuspartsnow.com and toyotapartszone.com. I'm sure you can get them from cdan and beno as well.
To find the part number, as an example for me, hit lexuspartsnow.com and then pick 05 lx470, go to powertrain/chassis section, and select component #25 front axle hub figure 43-03, and you'll see all the different snap ring sizes and part numbers. The ones on mine from previous owner were 2.0mm - don't know if there's a 'default' size or not. I found that on one side after rebuilding the cv joints that 1.8mm was needed and on the other side i believe 2.2 mm might be a better fit - I have those 3 sizes at hand waiting for the next wheel bearing repack at 120k
Part numbers for convenience:
2.8mm = 90520-31005
2.6mm = 90520-31006
2.4mm = 90520-31007
2.2mm = 90520-31008
2.0mm = 90520-31009
1.8mm = 90520-31010
