Hi guys,
Looks like I may have a busted tranny.
Here's what happened:
I drove back from Lake Tahoe on Mon evening (to Sunnyvale) and had just pulled into Berkeley and exited the hwy when I heard a big whining/grinding noise and immediate loss of power. Luckily I was on a small sidestreet and was able to pull to the side and stop withing 50 ft. I tried to engage the tranny but kept getting the same whining/grinding noise and could not get power to the wheels. This happened on all the gears (D, R, 4,3,2,L). I tried shifting from High to Low but the same thing. I had someone pick up my family and then had AAA tow my rig back home - luckily I have the premium AAA so the tow was free. The rig is now parked in my driveway and I now have to troubleshoot and explore options for fixing
Some info on the rig
2003 LX 470 with 5spd tranny. 110k on the speedo. I bought this in 2009 May with 81K on it. I had done all the fluid replacements then (including tranny fluid flush and replace with Redline synthetic ATF). I have 4.88s and ARBs front and back.
Some other symptoms / info:
- Park will not hold the vehicle.
- No check engine or other on yet
- Rig rolls smoothly with Transfer case in neutral - i have'nt yet tried with any other combination.
- Transfer case shifter moves normally
- Visually I see no damage to the tranny or tcase. Don't see any oil spill either but I will check again after removing the Slee belly plate.
- Before this problem the tranny/drivetrain was working perfectly. I had no indication of any problem except: I used to get some increased vibration at around 55mph and around 75mph, but I had assumed this was because of a slightly out of balance rear drive shaft as I had mangled it on a rock and then had a local driveshaft shop rebuild it. Now I'm wondering if it was from the tranny.
I got some great insight from this thread
https://forum.ih8mud.com/100-series-cruisers/445016-another-100-tranny-gone-2002-96k-help.html
I'm going to spend some time now to troubleshoot the problem and decide on a course of action - can use all the help/advise I can get. I want to make sure I have pinpointed the problem - I realize there is a chance some other part of the drivetrain is damaged. Here's my plan as of now - please let me know if there is anything else I should be doing:
- Check for fault codes (I have a scanner handy).
- Replace Slee belly plate with OEM cross member so I can see what's going on.
- Check condition/level of ATF
- Try and roll the rig with the Tranny shifter in various positions.
- Remove front and rear drive shafts and try and engage the tranny.
- Check the dash indicator lights when moving the shifter (with engine off)
- Check the condition of the Tcase oil (metal shavings etc)
Do let me know if there is anything I should not do to further damage the tranny.
Will post back with my basic troubleshooting.
