Bumper Material Question
Rogers, Arkansas
I'm in the process of designing and building up a front bumper for my 80. I planned to use 1/4" CR Steel plate, until I was "given" 1/4" aluminum diamond plate. I'm thinking I will make a steel skeleton and skin it with the aluminum for a nice finish with replacable plates. Any thought or experiences? I'll provide pics of my disign if anyone is interested.
How are you going to attach the aluminum skin to the steel frame?
I was thinking high grade socket head cap. Did you build your bumper? The more I think about it, the more I lean towards steal.
Yea I made mine..........I think if you are going to build your own, you can be very specific with your design for your own use.
You don't have to get too fancy to out-do the merrits of the stock bumper........IMO at 43lbs it is purely cosmetic.
If you are wheeling in a rock garden you need to be able to put the weight of your truck on your wing, on the otherhand if you burn around on sand or farmland you may never need more than a tube.
From my experience wheeling with my 80 before and after the bumper upgrade I like the added weight (not too much, just enough). The front tires stay planted (particularly when climbing).
I used a combo of 5/16 and 1/8 plate and I think it ended up weighing 127lbs.
Here is what I have in mind.
ambitious design - lots of bends, or lots of welding.
I'd stay away from the aluminum diamond plate for the main bumper. The diamond plate doesn't slide as well as smooth, and aluminum is soft enough that it will scratch mutch easier.
I'd do it out of 3/16" steel (1/4" is overkill, 3/16 is what most aftermarket ones I've seen are). Then if you want the shinny look of aluminum, make a top plate for bumper out of the diamond plate you were given.
Thanks. I have the quote for the 3/16" and 1/4". I've got a friend that will run a stress analysis to determine what benefit the 1/4" could provide. As for the bends, I've designed each piece so they can be cut from flat stock and welded together. I've got a drawing that I can adhere to flat stock and cut out with a band saw. I'm hoping it will come together pretty quickly.
Ambitious was the nice way of saying it's going to take a freak'n long time to cut all those pieces, seam weld them, and polish the welds.
You can have your friend run the stress analysis, and it'll show 1/4" is stronger than 3/16", what it won't tell you is what the impact force of dropping off a 3' ledge onto a bolder is. The shape you have there is plenty strong to be made out of 3/16". Throw a couple ribs on the inside to maintain the shape while welding it up, and keep the spans down and you'll be fine with 3/16".
I'd start with the top piece shape - make that, then the bottom, then several ribs. Tac the ribs to the top piece, then tac the bottom piece - make sure everything is straight, then start laying your flat stock strips on. Do the middle section first. Then the end of the wrap arounds, then come back to the corner last. You can grind and trim those pieces to fit if there is any error in the rest of it.
You are so right on the length of time. I have a plasma cutter at work and I might try to use it. That would cut down the time. As designed, the expected weight is close to 115 lbs (1/4"). However, it doesn't include all the welds, bolts and extras.
On your bumper, how did you attach the sides to the vehicle. Do you have pics I could learn from? Thanks man.
It's not necessary to attach the sides to the frame, but as for your material, 3/16" would be fine for the bumper itself but I would personally use some of the 1/4" for the frame attachment points. I'd also look at getting some 1/2" or stacking a couple peices of the 1/4" to make some tow point attachments.
Best would be to build your frame attachments so they pass straight through the front of the bumper with the tow attachment.
I actually am not done with my rear bumper yet. All I have so far is the flipped hitch, the lower piece, and an exhaust cut out. Just experience doing my sliders which each have 4- 60" long welds to get a certain shape, I know how long it can take.
Did you pick all your shape material to be stock sizes? If you did it'll make it much easier.
There are alot of different ways of attaching the sides to the vehicle if you want to go that route. Look in the FAQ for bumpers. Search for rear bumpers. TiredIron did a real nice rear just recently made of multiple plates welded together.
EDIT - Just realized you're talking front bumper not rear - so forget the part about attaching the sides, and search for front bumpers, duh....
Yes, I've selected stock plate to start with. I'm hoping it will make it all easier. The function of center protrusion is to allow room for a winch in the future.
What do you think about making the bumper a pressure vessel. I heard that people could be killed in an accident, but I would like to hear your thoughts.
I don't think you need the protrusion for the winch - you can see on mine it's pretty much straight across from one frame rail to the other and I'm set up for a non-integrated winch (this is a frankie's offroad bumper he custom built for me)
It's possible to get a tank to explode under pressure, sure, but at 3/16" plate, I doubt that would be much of problem, especially since you'd probably be running 125-150psi max. I personally wouldn't do it for no other reason than I'm nto a good enough welder ;).
The ribs I've designed are just like the ones you sketched. I plan to do the top first, then the bottom and then everything else. I've got the ribs places so they will bolt right up to the frame and allow me to place my d-bolts at that location.
This is very close to the way I put mine together.....only I started at the bottom.
The entire reason I built mine was because I had to have my M8274.
I also put mine together on the front of my perfectly level truck on a perfectly level floor.(this way you can measure from the floor)
For the top shape I used the back edge of the stock bumper clamped to the plate and ran me plasma along it.....perfect fit:D.
Search for "custom 8274 bumper" I put some pictures in that thread.
Be careful while you are stiching it up (keep things cool) measure lots.
If you are buying a winch that will fit in a short bus bumper.........go and buy a short bus bumper, they are very nicely finished. Then you can custombuild a rear bobbed jobby so I will have plan for mine:flipoff2:
Take your drawing to a local sheet metal shop and see how much they will charge to brake it up for you. If to much talk to the brake operator for a side job for him. :cheers:
I designed the bumper to have multiple small pieces that I could individually assemble. I was thinking about having a machine shop quote a cnc plasma or flame cut. If the price is not to high, I though I could make a few for my buddies.
I was looking at it as having 6 + parts depending on the center portion. If I am looking at your drawing right and if I understand your wanting to make separate parts I am counting something like 33 of them, is that about right? Then add the gussets. I think it would be cheaper to make in as few parts as possible and faster to put it together. Not counting the center I see 6 parts with 4 bends each giving you 4 seams to weld. If it was to be flat in the front then add one more seam to weld or just make it one piece. I would go with the one piece! If going with that center part as drawn it looks like a 3 piece like you have it and weld it to the 1 piece front part. Add some plate 1/8” ¼” ? under the top of it where you want the winch add the gussets and if you want add the shiny diamond plate to the top with carriage bolts for a smooth look or some black alien bolts for a different look. A good sheet metal shop could make that out of one piece minus the center part. Do some flat pattern lay out give that to your machine shop if the sheet metal shop does not have a cybernation machine or similar have it cut out in one piece and have it broke up for you. You have a good design there ! I am just looking at it from a tin knockers point of view. I can not say that one piece + verses thirty-three + would be any cheaper for you $$ wise but it would make it a lot faster to put together. And there you go thinking of others again! :cool: :cheers: Brian
Roy, I really like the looks of your design, but I agree with others, it looks quite ambitious.
As you build it, it's going to be hard to hold the pieces in the correct locations to tack together. If you had someone cut the pieces out with a CNC plasma or similar, you could make it self jigging like this:
http://ballisticfabrication.3dcartstores.com/Dual-frame-link-mount_p_24-1164.html
and sell kits to others (I'd probably buy a kit and lose my ARB that sticks out so far):
I'd say definitely 3/16 thickness for the main part of the bumper. My sliders are 3/16 and I've hit them pretty hard on rocks with just scratches. Keep in mind that your frame is not even 3/16, at least in the rear. I can't remember what the front looks like. Ribs behind it like you've designed would really stiffen it up. You could thicken up the lower edge that would take the most abuse. The lower edge on my ARB does show some damage and I think its 3/16.
I don't think the FEA would be worth the trouble. I started to do it at work when I designed my rear bumper. The best that it would show you is where it's going to fail when it gets hit with some huge force that you've pulled out of thin air. But if you do try it, you need to use thin elements because of the mesh size that you'd have to use--that's what a friend that does FEA for a living told me, anyway. To me, it seems like you could lower the mesh size to 1-2 mm and get away with it--although it would take forever to solve.
I wouldn't worry about the pressure vessel. It's only air and its only 100-150 psi. I wouldn't put a CO2 tank on my front bumper, but that's a lot more pressure. I bet that bumper would hold a lot of air. I just put a 5 gallon tank where the spare tire used to be under my rig. Welding it air tight could be a problem too with that many welds, but you could probably coat it with something inside. I think I've seen something for the insides of gas tanks that might work. Any idea what the inside volume is?
You could take a welding class and build it as a project. I took one last spring at NTI in Springdale and build most of my rear bumper in the class. It met every Monday evening for three hours (6-9). $180 for the class (which my company reimbursed me for), so free use of a plasma cutter, huge MIG, TIG, stick, electro hydraulic shear machine (would cut 1/4 easy), bandsaw, and lots of free steel that was donated to the school. It was a nice break from clicking a mouse all day. I think I'm going to take the machining class next semester since I just picked up an old metal lathe from a retired machinist.
Your bumper should be a fun project. I was wanting to build a front bumper too, but I got impatient and there was a group buy on some ARB's.
Anyway, just my $.02
We need to go wheelin' some time. I forgot to send you an email last time I went. 80's are rare on the trails.
David.
