Building a heavy duty Toyota service truck - Hino 145
UZJ40
OEM(ish)
LV, NV
I've always loved service trucks... I don't know why, but I guess the thought of being able to fix or do anything anywhere you are would be pretty awesome.
I did some welding work for a friend, and he gave me an F450 with a bad motor, but it had a really nice 12ft service bed on it with a 2,200lb crane and compressor/generator. So, I was on the lookout for a truck with a similar wheelbase and rear wheel placement.
Anyone that has seen my other vehicles knows it had to be a Toyota, and it had to be white.
I've never owned a Hino, but I've always been curious about them. This one popped up about an hour from me, so after taking my tape measure, I knew it would work perfect. I happily drove it home! Only 117,000 miles, so it should have plenty of life left!
Home, next to my smallest white Toyota truck -
The donor F450 -
Taking the bed off -
Fit SOOOO well on the Hino, I was extremely pleased! Rear wheels fit perfectly in the wheel wells. After new tires and tinted windows, it looks much better!
Here's a before of the driver's side cabinets. I will put the majority of heavy stuff over here to counteract the weight of the crane.
I bought the 27" USG box. It was about 3" too tall and 2" too deep, so I trimmed a lot off of it to make it fit in the largest bay -
This was all that was left -
It fit in the cabinet after all that trimming! Looks good next to the pack out stuff -
The air compressor was really nice.... 15 cfm, but the generator was 3,500 watts peak, and 2,500 continuous. I plugged my little Miller 140 in, and it barely welded. I knew it wasn't going to cut it. I found a really nice Miller Bobcat with only 240 hours on it. Even though this will easily run my little 140 or 210, I will need to learn how to stick weld as it will be easiest with this setup.
The compressor is now off, and I put a little pancake compressor in one of the passenger side compartments.
x2, is there a business plan for this? Seems like a lot of investment for private use only.
Very cool.. do you know what engine this truck has?
This is very neat
Heck yeah!
What are you going to use it for? Sweet truck.
Appreciate the comments fellas!
I do a lot of side work, all by word of mouth. Its mostly at the local airports around here. Not working on aircraft, but more like tugs, dollys, hangar doors, etc.
I also buy and sell a lot of stuff. A lot of it is medium sized equipment and tools. This truck will help me fix it on site, and do some further diagnostics before purchasing.
It's also a good backup plan in case I ever do need more income, and I can possibly advertise my services.
The engine is a J05D 4cyl 4.7L turbo diesel made by Hino. The transmission is an Aisin 450-43LE, which I believe some guys on the forum here have used in various applications.
Thanks again!
