Early engines used a bend-up locktab on flywheel bolts.That's what I thought. I am just going to put them in with the red loctite and be done with it.
OK here is a list of what I need to do yet.
- Find the spacer that goes between the top of the TBI and the bottom of the plastic plenum I got from a 4.9 TBI Caddy.
- Tap the plastic plenum for 1/2 NPT to get the air temp sensor in place. There are a couple of places on the piece that look like they were designed for this purpose.
- Wire above up.
- Find a crush washer for one of the smaller plug bolts for the oil filter mounting flange.
- Put on balancer and pulley.
- Modify alternator bracket for the CS 144.
- Find appropriate belt to fit.
- Finish off plumbing for the cooling system.
- Finish off plumbing for the fuel system.
- Tap block for knock sensor.
- Wire up the rest of the knock sensor.
- Bolt in starter.
- Wire up LC-1 WBO2 sensor.
- Hook up the PCV hose to the plastic plenum.
- Create a mounting bracket for the EDIS 6 pack.
- Wire up the battery, starter, on/off/starter switch.
- Wire power to MS2 Extra.
- Fire it up!
- Miller time.
- Pass out from exhaustion and the pain from the bursitis in my right shoulder.
OK I figured I would put up 2 pictures up of the tool I made to take off the crank pulley nut when I took this whole thing apart. This made taking the nut off as smooth as butter. It is now part of my engine test stand... ain't metal grand?![]()
BTW do I need one of those fold up lock washers for this thing or am I just fine cranking it down to 130 ft/lbs?
i would get that lock washer - i would say toyota must have put it there for a reason
- looking good!
Some of the Gates hoses that I ordered started to come in. This is the top radiator to water neck. Gates compared to the old one that was on there. Big difference in quality.
I guess what I would be concerned with is:
1: there is no camfer in the rod cap bolt hole. Its straight through.
2: the rod bolt shank clearly is tight clearance to the tolerance of the rod cap hole, this is what centers the cap correctly, and ensures the "circle" halves have not shifted...
Our bolt (kit 203-6004) does not actually have a knurl. I still think it should be tried even though the locating diameter is .0015” too small. Differences in locating diameters are often “made-up” in the concentricity.
No No I was asking if there WAS a lock washer... I don't remember.
