Build Build Thread - my Enola Gay FZJ80 1994
Almost our has a center rod that will help to keep the tool centered on pressing the old bushing and more important pressing the new one in
Mystery unsolved
When I ordered all bushing I used the EPC and VIN, but on the rig this rod had bushings on both sides one side doesn't appear in the catalog
Does someone knows as the part number?
So I took a few beers and drove to my friend's house and we worked all the holiday
He worked and I sat on my filed couch and drank beer and gave him suggestions and a headache.
We connected the fridge front and rear bumper lights, water pump compressor license plate bumper lights leds on the upper tailgate and CB Motorola radio
We installed the consumer panel with volt meter and kill switch fro each battery.
While we were there I tidy up all the spaghetti around main battery
adedd engine temperature meter and alarm and dual battery system
Time to dirty our hands
Removing the HPS silicon house I installed 2 months ago all houses will be OEM including 3 rad houses 4 bypass hoses
Rear heater bypass (gates green)
PHH I don't know if to go with Gats green short like OEM or bypass the metal pipe????????????????? Need to decide by tomorrow
Two New OEM ventilation hoses + garment + valve
New OEM vacuum line to booster
New OEM hydraulic brake hoses
All gaskets, new OEM
EGR out
PAIR out
All vacuum VSV EVAP canister out
And many while you are there:bang:
Starter failed miserably in a petrol station I didn't get love from the people that morning that wanted to fill up and go to work I used a metal road to bang on the starter until it start up drove directly to rebuild shop
My starter unit was overhauled and while I was there I changed the alternator with a refurbished unit they had on the shelf
For the last few weeks I had a very unstable ruff ideal the OBD1 reader showed that bank 1 O2 sensor failed
I ordered from Rockauto 1 cheap 32$ O2 sensor it was the last one in stock (I am waiting for Mr T sensors To arrive from Japan) when it arrives in the box was NTK made in Japan OEM O2 sensor, but when we went to install we found out that the connector was all corroded from water that went in :(
I ordered 2 connector pigtail from Archie @ATXFJ80 and we renew the O2 harness works perfectly.
I used the rest of the this winter sunny day and drove to the fisherman village to the ruins of the old Roman aqueduct that was rebuilt by the Crusaders and ruined again by Slach a Din during the occupation of the land by the Muslims. You can still see parts sticking out from the sand, outer parts were reconstructed by arciologes
I’ve been trying to decide between standard type or silicone radiator and heater hoses. What made you change them? Thanks!
Breakfast on the trail
Arab Mediterranean fresh salad (onions, tomatoes, cucumbers and parsley Lemon and olive oil)
Beacon and eggs and cheese for the bad Jews
Kosher eggs and cheese for good Jews
Pita bread, hummus and tehini and Israeli soft cheese
Every hour or so of driving we stop for boiled Arab coffee and sweets
