Budget beefy bolt on rear lower control arms.
Coastal, SC USA
I severely bent a rear lower control arm in my last trail outing and did a bit a searching to find a budget friendly but stronger bolt in replacement. After posting here for recommendations I ordered a set of Mevotech “Supreme” arms from Rockauto (1995 TOYOTA LAND CRUISER 4.5L L6 Control Arm | Shop Now at RockAuto - https://www.rockauto.com/en/catalog/toyota,1995,land+cruiser,4.5l+l6,1276680,suspension,control+arm,10401)
Although not stated anywhere on the rockauto website, the Mevotech arms look to be rebranded SPC arms. They are larger diameter than stock and have one standard rubber fixed bushing and then the frame side has a joint that is a flexible joint that looks to be similar to a booted spherical joint to aid in flex. I paid $234 shipped for two new arms which was about $150 less than the best priced SPC branded set of arms I could find anywhere else. Just thought I’d share in case anyone else is looking for a budget minded set of lowers! That mic pics show the diameter of the original arms and then the larger Mevotech arms.
Tube strength or tensile force resistance is calculated on material tensile strength, tube diameter and wall thickness. At 1.5” I would be curious what the wall thickness is.
If you are bored you could sawzall the bent OEM link and see what that looks like. I’d love to know the OEM wall thickness.
Well, first trip out with the new Mevotech/SPC arms and I bent one. Not too bad but slightly bent to the eye. I don't really remember banging it hard enough to think I bent anything but I did. For $235 it was worth a try but they definitely weren't what I hoped they would be. Maybe I'll see about getting these beefed up some by a local welding shop if they think they can do it without melting the bushings.
Look to get a 7075 link. I run 7075 on all my rigs and the cruiser will be getting a nice replacement set when I finish the rear suspension.
If we are talking true budget, some 3/8” wall DOM at 2.5” is enough and also cheap.
Here’s one of my noncruiser 4-link setups with 7075 front/rear upper and lowers.
Working on a budget I’d source a set of OEM and weld on additional material. Hit something hard enough and you can bend most anything. Also give you the opportunity to adjust pinion if you needed by sleeving a set of OEM.
I’m running spc arms too. No complaints. Rear moves easier
I followed this mod idea many years back and it works great. Simple and stout and allows to keep factory OEM rubber bushings which work excellent overall, durable.
And still going strong after many miles of testing
