Bucket Seat Question
Seville, OH
Been thinking about changing out my stock split bench with buckets in my 40. Seems like there are a lot of options. Some of them on the cheap, some of them will break the bank. I will be doing a X-Country drive CA to Ohio this fall. And I'm thinking an economical set of buckets would be a good idea.
There seems to be pages and pages of new and used bucket seats on EBay. But I'm not sure what would work / fit in a 69 without a whole bunch of modifications. I'm not a welder. I took a welding class in college, actually got an A - but that's not the point - I don't have a setup and probably couldn't do it very well anyway after 15 years. Someday... But I can bend, cut and drill. Don't mind that. I'd like to retain my toolbox under the driver's seat, and of course I have the inside fuel tank to deal with on the passenger side.
I see lot's of rigs on this site where guys have put buckets in. What type of seats work the best ? From what vehicles (if used) and what years ? As for new seats, who makes the best seat for the price ? How dificult is it to adapt them to a 69 ? A lot of the kits I see are for 71 and newer.
Any experiences to relate or suggestions ?
I'm in the process of puting 04 Vibe seats in mine that I got from the junk yard. Really comfortable. Just be carful with the heigth. I'm going to have to lower my drivers side a little so I can see the traffic lights ok. But my legs, ass and back are a lot happier. ;)
Todd- I put Fiero seats in my '73. They are a little harder to find (I think $100 for both) and will probably need to be redone (unless you can find a mint set). I picked early 80's which had speakers in the headrests and they work great. I can hear my stereo well at any spped. My brackets are fabbed up from angle iron and grade 8 hardware. I'm having them recovered next week and would be happy to send you pics. Good luck.
Thanks fellas. I saw the other post, and planned on surfing a few boneyards around northern CA. Was curious about what vehicles to look for, and what years. The big thing I don't want to have to do is re-fab everything to get them installed which is why I asked about seats for a 69. It's a little different set up than the later models with the toolbox on the driver's side and the fuel tank on the passenger side.
Sounds like I need to look for compact type cars - Fieros, Civics, etc. I kind of liked the idea of a captain's chair type seat - with the arm rest. But it seems like they may be a little too tall.
i took the seats off their frames on my 72 and then bolted the new ones to plates on the seat frames. for example the drivers seat is on a frame that allows it to hinge so you can get to the toll box. that frame comes apart from the seat to leave a bare platform for new seats. all you have to do is bolt or weld a plate across the framme and bolt the new seats to the plate. hope thats not too confusing. wish i had a digital camera to show you what i mean.
Hi All:
I swapped in a pair of 1994 Camero bucket seats in the place of the worn-out factory bucket seats in my '74 because I needed a seat with better lower back support (I injured my back at work in 1997.)
One can certainly fab-up adaptor brackets/plates using a drill, grinder, and bolts - that is what I did. It was a bit of a "hack job" but held the seats securely for several years. A mistake I made was not retaining the ability to adjust the driver's seat (slide forward and back.) As part of the body tub swap project that the truck is currently undergoing I plan on re-engineering the seat mounts to allow for adjusting the driver's seat, and will probably weld the pieces together since I now have access to a welder.
For seats, I'd suggest just going out to a big wrecking yard - I found the Camero buckets for $100/pair at a 'yard. I just sat on a bunch of the seats until I found a pair that were comfortable, in good shape, an acceptable color, and of the size I was looking for.
Good luck with the seat swap project!
Alan
Seattle
Well, thanks for everyone's help. It's taken a few weeks, but I got the seat upgrade finally completed.
Went to the boneyard, got 2 buckets out of a 97 Cavalier - $50
Bought some angle steel, and some hardware - $20
Took out the old bench seats, removed the passenger side from the seat frame and used that to mount the passenger bucket to. Worked pretty good.
Mounted everything in and adjusted for height, level, etc.
Bought CCOT shoulder harness seatbelt kit with regulators - $140 (needed them anyway - just had lap belts). Had to move the speakers to mount the regulators so they worked. Actually, probably a better spot for them anyhow.
Custom seat covers for 97 Cavalier from EBay - $40
Bought CCOT center console, semi-custom install - $200
Total - $450 ($250 if you don't include the console, just the seats and belts - $110 for just the seats)
Much improved comfort and stability, probably safety too with the belts. Seems a lot easier to drive. The wife says the cup holders are her favorite thing that I've done to it since we got the 40. Should make rallying from CA to Ohio in the fall much more tolerable.
A couple pics;
Supra Seats
I used toyota supra seats I got from a junk yard for $50. It even has an air lumbar support with adjustable side support. Used 1x1" box tubing for the frame.
My '72 has evaporative emissions control device in the backrest in the middle of the bench - any idea where/how to relocate this with a seat change? I need more space for a bucket seat on the driver's side. Thanks in advance, Claudia
Mine came with seats out of a Granada, seats almost touched the steering wheel. Using 86 Camaro seats.
I'm in the process of putting some $20 civic seats in my fj40. I just finished the passenger side and was not too happy with the height of it. My head sits maybe 5" from the roll bar, which could be too close. I don't know how high they should sit, since mine never came with seats, and only had random chunks of the brackets with it. Maybe one day I'll actually see that cruiser roll.
Try the sunmmit seats
Part# SUM-G1159. Ford the price they are pretty nice and they are comfortable.
I have a set in my 65 and i love em.
You will have a problem with seat height especially for the passenger due to the fuel tank so find the lowest seat you can get.
I have power seats out of a 95 Camaro and made a mount that puts the bottom of the seat pad just an 1 1/2 above the fuel tank and I'm still looking through the top area of the windshield
