Broken Rear ABS Sensor Bolt $@#%&*
Columbus, OH
I did my Rear Axle job today, new bearings, seals and rotors. In the process of taking the first side apart, the hub and rotor would not slide off all the way. It felt like it was catching on something. I looked at the FSM and it said to remove the bolt and disconnect the ABS speed sensor. Instead of removing the bolt, it decided to twist off. This is really a big oh sh!t because there is no way to get a drill in there to drill it out. The bolt goes into the same 3/8 casting the callipers are bolted to. I was hoping that the hole went all the through the casting and the other side of the bolt could be accessed by removing the dust shield. Then I noticed that the brake line and emergency brake cable are both connected to the other side of the shield. Of course they are rusted, so I decided not to pursue this option. I asked my friend who was helping me if he wanted to take his MIG and tack the ABS sensor down. He did not like the idea of welding near an electrical sensor and felt that the sensor was permenantly glued down with the rust. I put some JB Weld around the perimeter of the sensor bracket in hopes of keeping it glued in. Any suggestions on what I should do here? Should I try to remove the bolt? or should I just leave it alone? Thanks in advance for your suggestions
Tear it apart and replace parts as neccessary. Brakes in particular are no place to begin afro-engineering things.
take it apart and remove that "casting" for improved access to the buggered bolt. Based on what you've said (rust) the bellcrank pieces for the ebrake on that side may break during dissassembly or be siezed. replace the bellcrank pieces (there's a kit from toyota (ie Cdan) that is not much money at all.
My comments are based on my recent experience in relacing that bracket/backing plate on my '94 - Incidentally, the paper gasket between the flange and the hub should be replaced (I ended up using hylomar as my local dealer didn't have the gasket:rolleyes:) otherwise 90 weight will leak down the outside of your wheel/tire - trust me:mad:
I just went through this myself while replacing leaky axle seals early this morning :doh:
Other than routine brake maintenance and drain and fills, I've never touched the rear axle and I'm pushing half a million miles, so it was definitely due :meh:
Like an idiot, I too followed the FSM and tried to remove the ABS sensor, even though there's absolutely no reason to (at least on my 97) :rolleyes:
Ended up snapping the bolt on the driver's side sensor :bang:
No room for an extractor, let alone a drill :frown:
It was midnight and I had just finished a long shift at work, so the last thing I wanted to do was tear down the backing plate :eek:
Instead, I decided to just drill through from the other side and install a bolt and nut :idea:
Worked like a charm :clap:
I don't ever remove the abs sensor on the rear no need too that I've seen, drill through like above and call it good
