broken hard brake line?
North Cadillac
So how do you fix this? :mad: :mad: :mad:
Thats annoying as hell! I would think the best way would be to replace the entire line. You could get a shorter piece and splice it in, but this requires a lot of double flares and fittings. Just don't use compression fittings. I hate it for you. How did it happen?
Well after looking at it on my truck..... That line is probably more trouble than its worth to try and replace the whole thing. I'd just get a piece of line about 24" with the metric fittings and a couple of unions and repair it like that.
No really, How did you break that? :flipoff2:
Honestly, i was going to PM two of the hoses at the heater valve on the firewall. I decided while i was at it, i would just remove the hood since its just 6 bolts. So i took a paint pen, marked the hood locations on the bracket, unbolted the strutts from the truck (left them attached on the hood), then removed the bolts from the hood arms. As i pivoted the hood back towards the front bumper one of the strut brackets caught hold and yanked. :o :mad:
I sat the hood back down, but it was too late, the damage was done. :ban:
Just buy the hardline from Toyota. They are not expensive.
That is starting to look like my best option. I have gotten some unions and compression fittings, but the bends in the stock line and a slight coating on the line make this patch job a real sketchy one at best.
I'm calling Cdan. :doh:
Compression fittings would not be the way to fix this. Replace with new. I have purchased new Toyota hard lines and they are surprisingly cheap-in the neighborhood of $14 or so. You can also bend/double flare your own pretty easily.
i feel like such an idiot for even letting this happen. Lost focus for just a second and this is the result.
What makes me even more madder... :) .... is the fact that i had no real reason to even mess with the cruiser today. I shouldn't have even touched it.
this is just great..... so far, all the dealerships i have called within 200 miles of my house say that their computers show that the brake line i need will have to be shipped from Japan. They say there are none in the US parts computers. :(
waiting for cdan's answer..... i hope it's not the same bad news.
That line is longer than you think, It goes all the way accross the firewall.
47315-60372, list $29.52, none in the United States, none in transit, would need to come from Japan. At least 2-3 weeks.....:frown:
Dan, would that brake line be the same part number for a 92? There is that 92 being parted out in Wilmington, NC in the parting out section. Might be worth a road trip to the beach...Maybe someone local could pull it and meet you halfway for lunch or something....
Nope, not even.
Concrete-Just order the d#mn thing and be happy it's still available. In the mean time, bend up a new line of your own. If you were local, I'd do it for you. You could make a crappy but working line in 5 minutes, or a perfectable usable line with exactly the right bends in about a half hour.
If there is a Pep Boys near you, they have sections of pre flared tube in the back. Make sure you get the metric one, with the 10 x 1.0 fittings. It is super cheap, so get 3 of the longer ones. Bend it over a socket or something else hard and round:flipoff2: to the approximate shape it needs to be. Install the fittings at each end, and gently press the tube down to some supports. Zip tie in place. THen bleed the system and drive. Three weeks from now when Cruiserdan's yacht gets here from Japan, replace with the proper line and bolt it in place.
If you can make it here to Sacramento, I have a tubing bender, a double flare tool, and a 25 foot section of good line from Classic Tube, with the proper fittings.
Well, thank goodness someone totaled their 80 and decided to put a car cover and a tarp over it and leave it in thier backyard.
I was able to ride not even 2 miles down the road and extract a perfect hard brake line off a rolled 80.
So, it is almost fixed. All i need to do now is bleed the brakes and have help replacing the hood.
I will never try to remove the hood alone again......repeat, i will never try to remove the hood alone again! ....repeat as many times as necessary.
Thats great to hear Alex. when are you planning on putting your hood on? I might be able to sneak out of work tomorrow and lend a hand in the afternoon.
Glad you found one. I'm just reading this today. I would have offered you one. I have a complete set of rust free 80 hard brake lines in my storage shed. I couldn't throw them out.
