Breaks breaks and more breaks.
Boston
Website
www.burnmachinefilms.com
Question 1.
I need to replace both my left and right rear hard lines on my 94. One sprung a leak so I'm assuming all the lines will nee to go soon. Does everyone just bend their own or order the originals?
Question 2.
Im replacing my rear calipers. One has a stripped (completely rounded) bolt and of course its the lower one behind the shock. Any tricks on getting these out short of drilling? I was thinking Id weld another nut right onto the stripped head.
Parts???
Nappa?
Vendors on here?
Sam Adams/Budweiser for this one?
I thought there were going to pictures of some seriously broken things here...
One every Toyota forum I have ever visited the overall consensus on parts is OEM, unless discontinued or you are looking to upgrade. IMHO I would suggest buying the Slee SS brake lines and be done with it.
OEM calipers and EBC green pads.
If your rotors are slightly worn, check for minimum (30mm I think) and replace with more OEM.
If the rotors in the front are good, then spring for 100 series EBC green pads. They are larger and thicker and are tough to fit on new rotors.
OEM hardlines, lots of good choices for pads, I'm running Hawk LTS and I like them.
How hard a job is this? I just found out today my rear line behind driver back wheel is spraying. My husband is cussing...
This a simple job: Just make sure you order you lines from a vendor on here or Toyota. if you're going to try and bend your own is a hassle and you need the flare tool. Bleeding is the hard part in these 80's. It took me 8 try's before I finally got all the air out, bleed
the valve correctly and had a solid peddle.
Thank you. Does anyone know what it'd run to take it in and have all the lines replaced? Or just the hard lines? I figure as soon as this one is replaced, it's going to happen to another one. Wondering what it would cost us to take it in somewhere and let them do it
It really depends on where you go for service.
here's an example : A Toyota dealership will charge 90 to 105 per hour for labor. To replace all the hard lines (under the truck) is about 7 hours of work if they have to drop the tank - 4 hours if they don't- if they don't run into any other issues.
Parts will cost anywhere from 300 to 600 for all the hardware, the new lines and the valve.
this can vary depending on whether they bend their own lines will get them from overstock. All in all... it can cost it can range from about $1600-$2500 depending on the condition of the underside. I did my truck myself and it cost me about 620.00 in change.
Hope this helps?
I recently found it impossible to run new oem 100 pads (no squeal pads) and new oem 80 rotors with my older oem 80 calipers up front. Just created too much drag and would heat up the hubs in no time. Speculating new calipers may have allowed the Pistons to operate at a wider range. Just a heads up YRMV
I have EBC greens all around, 100's up front, and OEM rotors and Beck & Arnley remand calipers all the way around. Had some issues with crappy machining on a couple of calipers and one had to go back for different one but it stops good now.....
Between you both have you tracked down if we're talking leak from the hardline or (more likely) the soft line?
Changing your hardlines isn't out of question if you're in the salt belt, etc - but talking hardlines if you haven't yet been under there on cardboard is like fishing with dynamite.
Since you say it's behind the wheel I'd get down there & check the shorter rubber lines (assuming you haven't since not specifically stated) - the difference between hard lines & a simple soft line is big $$$
A arguement can be made to change (or inspect the crap out of the remaining soft lines), they are aging to the point of them being dry rotted or old & soft is just as likely as nicking the leaking area on debris kicked up either on or off road.
If the other soft lines show any cracking, a full set of either OE or aftermarket lines is still relatively cheap compared to paying to change out hardlines.
Agreed! I live in NewEngland so I replaced all the lines and the valve.
