brass drifts/punches or specialised steel bearing race punches for bearing work?
Toronto, NSW, Australia
Up to now I've just had cheap brass punches but they're easily worn. Found a set of steel bearing race punches made by mayhew (imported to Australia by Dawn Tools) and was curious about those. Brass drifts/punches are readily available but bearing race punches are harder to get.
What's the general consensus? I know the idea is to avoid damaging/scoring races or the seat where each race is fitted.
I just use a cold chisel from Home Depot to get them out. IDK exactly how hard a bearing race is, but its way harder than a cheap chisel.
Harbor freight has a pretty dang good race driver set with aluminum pucks for installation.
I use brass when installing and when I have a large enough area to hit when removing.
I do it for safety, as I have had a bearing race chip the steel chisel I was using and embedded it in my knuckle.
I will only use a steel punch if the brass one keeps shearing off the tip because it's too narrow.
I use a Cornwell set off the truck. Anything similar should be great. And no I don’t remember what I paid for mine but not that.
For wheel bearing race installation I kept an old inner & outer race and cut a slot in each.
These are then used to push the new races into place. can either be done by hammer or i use a long bolt & nut with plates and just pull in the new races.
The race with the cut slot then just falls out once new race in place
Scraps of mild steel, or brass.
I find brass chips away to easy, unless you are hitting on a wide/ flat surface.
Any well made cold chisel is gonna be too hard for use for installation of a new race.
I've used cold chisels to break races off many times, did so last weekend. There's always a risk a cold chisel or bearing race will break away in sharp shards.
If you've ever had to pull a shard out fractured metal out of your skin, safety glasses aren't even a question
I use the same method
I would personally recommend using an oval bearing rack punch designed specifically for bearing races but I also used to sell tools for a living and I am a believer in the right to for the job.
Something like this
These are designed specifically for bearing races and should not hurt the bearings races.
That being said bearing races are certainly a job that can be done with any of the techniques mentioned above.
Last time I did hub bearings I ended up doing some slight damage to the new races but was able to minimise it.
I'm keen to try proper race punches/drifts made for the purpose but I also have some old races I've hacksaw-cut for fitting new ones. Can't always find them as bearings are something I'm doing probably every 2 to 3 yrs.
Being a mechanic and dealing with various bearing races time after time I use this method, simple and saves having a 'kit' where parts go missing.
Regards
Dave
