Im looking at kind of a one off setup, I want to run the eldorado e-brake calipers I have with some rear chevy rotors from a different application, I'm kind of stuck to the rotors based on interference issues that Im not wanting to get lost on and change the direction of the thread too much.
The issue is that the rotor is thinner then the caliper with pads is designed for, with the piston all the way back it has around 1cm of clearance, (the rotor in new condition is thinner then what the caliper was designed for).
I'm thinking either I can make it work or I shouldn't try, if I do make it work it means maybe making a spacer using the steel backing from another set of pads or running it as is, if i do run it as is, do i risk pushing the piston out when the pads are completely worn out and a brake failure.
What say you? is the spacer a bad idea? should I just check the stroke to see when the piston dislodges or should I just say screw it and look for other parts?
