Brake Proportioning Valve
Palo Alto, CA
Brand new plug and play brake proportioning valve solution. Fits Toyota brake lines without any modification to the lines. Ports are 10mm X 1.0 female inverted flare.
Includes stainless steel nuts & bolt to install in the stock location on 9/75-7/80 Toyota Land Cruiser FJ40 / FJ55 with front disc brakes.
Replace your rusted original valve with this precision machined aluminum unit and restore your brake performance. No more rear brake lock-ups!
Brake Bias is adjustable, with range of 100 PSI-1200 PSI pressure (0 to 60%).
Link to easy-to-follow installation guide will be provided with purchase.
Price: $65 shipped
City Racer LLC
I'll keep this in mind if anyone looking at redoing the brake system asks about a P-valve. Looks nice. Looks easy to adjust. I haven't read "backwards" but do you sell it already "adjusted" to the correct pressure or do you send a how-to for it?
I'll keep this on mind if anyone looking at redoing the brake system asks about a P-valve. Looks nice. Looks easy to adjust. I haven't read "backwards" but do you sell it already "adjusted" to the correct pressure or do you send a how-to for it?
It comes pre-adjusted, but I also provide a manual on how to adjust and test.
The default setting should work for stock rigs, but different folks run different tire sizes and suspension setups, so the optimal setting depends on the truck.
Ordered one of these yesterday! Will document the install and provide some feedback when it comes.
Not to shamelessly plug my own products, but the set up I have in my truck now -- with the new brake proportioning valve and the new dual diaphragm brake booster (coming in October) has given my brakes a new lease on life. As much as I like OEM, it would be really hard to achieve the same level of performance and trouble free operation with the original parts from the 70's or 80's.
img_5937-jpg.1107180
Where did you get those rubber boots protecting the sensors on the bottom of your brake master cylinder? I need a few of those!
Those are OEM. I don't know the part #, or whether it's still available.
Is that a new brake master cylinder? Were those boots there when you got the truck?
The boots are just nifty... and my sensors could use the protection.
Yes, the boots are the originals on the truck. My MC is about a year old. It's an Aisin unit.
Sorry... one more question. So the new Aisin unit did NOT come with the boots? I also just bought a new Aisin unit and it didn't have them.
I've looked through ToyoDIY and can't find anything resembling those boots. Bummer. =)
It's not part of the MC, but part of that short piece of harness.
