Brake Pressure Switch replacement question
Kansas City, MO
I'm putting in a new brake master cylinder into my '78. The new one did not come with brake pressure switches installed.
Removing the existing brake pressure switches from the old master cylinder has proven to be harder than I thought. Is there a special tool required?
Someone ripped the electrical component of the brake pressure switch system out long ago, so, if I cannot move the switches from the old master cylinder to the new one, I will probably just get some plugs. I came up short on finding anything after a quick trip to Advance Auto and Ace Hardware. Anyone have any ideas? What is the size and thread count?
Because the system probably hasn't been working in a long time, I don't really want to buy new switches at $30 a pop since I don't plan on rewiring the warning light.
Thanks.
no special tool - lubricant and force
Thanks. Realized that I just needed the correct size socket and they wrenched right off.
1 1/8" worked for future reference.
Thanks.
Why wouldn't you want a brake warning light?
Because the relative pain in the ass, plus time and financial outlay for a vehicle that might see 20 miles a week, if that, isn't worth it. I only have a few precious days to do any real work on the '40 over the holidays, so those calories are best expelled elsewhere.
My head is under the hood often enough that I can be my own warning light for impending brake problems.
1/8BSPT(tapered).
It's the same switch for all models listed from 1970 to 1980 with tandem master cylinders.
Single master cylinders didn't need one; you learn it has failed when the pedal goes to the floor...;)
You are the one doing the inspecting/fitting. Every master cylinder I have bought came complete with reservoirs and pressure sensors. If you are bottoming out and it still leaks I would say you have a straight thread going into a tapered hole. Try wrapping the sensor with 4 or 5 turns of teflon tape and see if the leaks stop.
Thanks. I haven’t bottomed out yet but my understanding was that the master was tapered. If they bottom out, I’ll get some copper washers which should resolve it. Sorry, I thought you used plugs and didn’t realize your MC came with sensors.
Just to follow up here in case someone runs into this, I used Permatex 54540 Pneumatic/Hydraulic Sealant on the tapered threads. It works on brake fittings. Was about $25 on Amazon and about double that locally.
My understanding is that the rebuilt masters sometimes have slop in the threads from cleaning them out and this issue can occur. It did in my case and this is how I sealed it up. Thanks everyone for your input.
