Brake help...
Washington
alright, so I've read through some other brake threads to see if anyone else had this problem, and perhaps a solution. I'm digging into the cruiser to replace the brake pads. Easy day. Only I go to push the piston back into its home and she won't budge. I mean, I bent the crap outta my C- clamp handle trying while trying to turn it. Tried going the bleeder route but I can't get those to move either. I've been bathing all parts in brake clean. But I'm feeling lost now, you guys got any ideas? More muscle? Many thanks
I had the exact same thing happen to me! Order a reman caliper from your auto parts store of choice. Oreaily's was like 85 bucks plus you get core charge back if you want.
yea i was just looking at Oreilys. thanks for the advice. and nice avatar pic Arkansas80
Make sure the piston isn't tilting in the bore while you push it back in. Easy to get them uneven when they are extended a lot like for very worn pads.
I usually don't even use a clamp or remove the caliper (for pressing pistons back in). I put a large screwdriver across the piston face, and pry against the center of that screwdriver with another one against the edge of the disk. I also open the bleeder screw when pressing pistons back in so all the old fluid is flushed out a hose and into a container.. Before starting anything I empty and refill the MC reservoir and you have most of a brake fluid flush done when you get the piatones pushed back in.
Rebuilding calipers isn't a huge deal if the OP wants to attempt it. Few seals is all about what you end up replacing. As long as the pistons are still chrome shiny then a simple bore cleaning and seal replacing is all you need typically. Toyota sells rebuild kits.
Seized Piston,
Get online and order the Napa rebuilds.
They come with a nice black coating, otherwise bodies will rust.
Napa requires your old caliper cores back.
Better, Faster, and not that much more than rebuilding yourself.
There is no more important safety feature on your vehicle than the brakes.
If you have AAA NAPA will take 10% off or subscribe online and they send you coupon.
Wish I went this route.
I saved about $10 buying reman calipers and it is rusty already and that was this fall.
Chk your brake lines for cracks.
If you can get rear bleeders loose now is a good time to put in all new fluid.
I think every 80 owner should rebuild a caliper at least once, that way they can appreciate how nice rebuilt calipers are.
I just got done doing all 4 corners on my LX450. New OEM rotors, new OEM pads, new OEM rear caliper soft lines, OEM rebuild kits, and a lot of cleaning. Ran about 2 pints of fresh fluid through the system.
I had always thought the brakes on this truck were good, but now they're freakin' awesome.
I found some corrosion on the front calipers/pistons. This resulted in the pistons binding a little and the truck pulling a bit while braking. Then the DS rear caliper froze and burned the pads up in 2 days. I ended up going to NAPA and replacing all 4 calipers. They initially ordered the rear calipers without mounting brackets. I didn't want to mess with those so I went back and had them re-order the correct parts. Once I got those everything was great. The NAPA calipers are very nice and work well.
