Hello all and thanks in advance for any help you can offer. I just bought this 72 fj40 and the first thing of note was the rear brakes dragged. I replaced all 4 wheel cylinders and bled the rear brakes. I do not believe I got the shoes adjusted correctly at this point. I think they were too far in. Performance was not improved notably but the squeak of the dragging brake was gone. Next I installed an OME lift and 33’s and immediately felt I needed a brake upgrade. I installed the JT outfitters front disc conversion. Install went fine and performance was slightly improved. I was still running the factory single resovoir master with NO booster.
So I ordered a booster and master from JT outfitters along with their bracket to get the booster past the firewall rib. Now this is where my problems started. I installed these new parts in the pics attached which also needed replacement of the majority of the brake lines. I lengthened the brake pedal rod and got the pedal back exactly where it started. I verified the distance from the back of the master to the plunger and made sure the nipple in the front of the booster moved forward enough to get action on the master. I also bought a Toyota wheel cylinder adjustment tool and turned the shoes out till they made the drums drag, then backed them off a bit until I could turn them freely
Since completing the install I have bled the brakes multiple times via the 2 person peddle method and moved a qt of new fluid through the system. I still can not get the pedal to build any pressure, you can pump all day and the pedal will continue to go all the way to the floor - it does have pressure or resistance but goes all the way down. I have also bought a harbor freight air power bleeder and it turned out to be a dud, pulled very little suction when I put it up to my finger and would not get hardly any fluid moving on the truck.
Yes I did bench bleed the master and also made up a set of lines to bleed it again when it was on the truck. This master booster combo is extremely tight and required finagling of the carb linkage to get it on. I’m wondering if I still have air in the system because of all the new lines or is there something wrong with my master booster combo? Notice the height of the loop on the front line off the master and it’s a bit higher than the fluid level in the reservoir - is this contributing? Thanks for any help in advance.
