I recently purchased a ‘78 all stock fj40. I had a ‘77 that I regrettably sold about 20 years ago. So, I’m going through the rig, getting to know it. I noticed the vacuum wasn’t hooked up to the brake booster and the holes were capped. The brakes work but they’re a little stiff.
So I ran a vac hose from the booster to the intake manifold thinking it would improve the stiffness at the peddle. Pulling out of my drive way for a test, I barely touched the peddle, and the brakes slammed hard full stop lockup. It released and so I tried again…full lockup.
So, I took the vacuum hose off and they went back to normal, alittle stiff, braking. I’m not sure what the vacuum is at the manifold but I’m going to find out. Is there some kind of PRV that should be on there? I have no Idea whats going on with that. I see pictures of other rigs with the hose hooked up so it must be a normal thing to have vac on the booster can. Why does mine slam tight?
