I also replaced front and back with the tough dog 0-2“ lift springs and had been suffering with a 1” driver side lean since put in. Stock rear Taller spring was on the passenger side so that’s what I did when putting in the tough dogs. Kdss system trick done several times. nothing helped, was getting pretty mad. Swapped rear springs so taller spring is on the driver side, with a 10 or 6 mm (forget) packer on the passenger side rear. Rear is now within an 1/8”. Driver side front 1/2” lower than passenger side. Guess I’m not done yet. They have a 1/4” front spacer packer shim whatever you want to call it available for Tacomas and the FJs. I’m gonna give it a shot.
