- Thread starter
- #21
Is this the wiring diagram you're looking for?
You rock! I'm going to jump straight from the ECM to distributor in the morning. Ill keep you guys posted. On a positive note the new AFM cleared one code.
The code coming back on as soon as you turn it to start but haven't started the engine yet sounds like some shorted wires. Otherwise there shouldn't be a single code if you've reset the ECU properly until you've started it.
Did you download a Factory Service Manual yet? They are pretty good with diagnostic information and checks. After you've visually checked the harness at the EGR valve, (replace the heat shield wrap with new stuff) and checked where it passes through the firewall, I'd go through and check the terminals of the harness where it connects to the back of the ECU. The FSM gives you values you can test for.
Do you have the trouble code section? From what I'm reading it appears to be code 12. One short flash followed by 2. If it is in fact 12 does the manual have any info on testing or diagnosis? New distributor in working order and good wiring between ECM and distributor.Hey Man, I'm at work today. I've got a 94 and I have the paper version of the FSM in the back seat here in the parking lot. Let me know if you need anything out of there. Id be happy to help. I know my EGR/wiring had been done (repaired and heat wrapped) prior to me buying my Rig for an issue muck like you described. Good luck!!![]()
